Need some help BAD, was doing a compression test and......
Old Dec 5, 2002 | 08:01 PM
geminis2k's Avatar
Default Need some help BAD, was doing a compression test and......
The adapter that comes with it is stuck in my cylinder head. Any ideas how to get it out? I bought the tester from AutoZone, it came with a gauge, hose, and then the adapter - My friend and I connected the adapter not knowing we didn't have to and it got stuck. I'm hoping we're not the only people out there that have gone through this so if anybody out there has some answers, please help!! The adapter is still threaded, but we can't get it out the same way we got it in (the hose)...
Old Dec 5, 2002 | 08:55 PM
94TealGSR's Avatar
Default Re: Need some help BAD, was doing a compression test and...... (Alex)
How hard did you get it in there?! Have you tried pliers on the hose? Even if you wreck the hose getting it out, it's only $30. Haveing someone else do it will cost you at least that much.
Old Dec 5, 2002 | 09:01 PM
ingrate's Avatar
25 Year Member
Default Re: Need some help BAD, was doing a compression test and...... (94TealGSR)
Are the threads inside the adapter crossthreaded? Just be careful, you REALLY DON'T want to strip the threads on the head.
Old Dec 5, 2002 | 09:13 PM
Mase's Avatar
haah my friend did this on his car, i went over, took off his valve cover, which allowed me to get a better angle w/ needle nose....and volia....it came off.....just be patient...
vegas hoe
Feb 16, 2008 05:06 AM
cornhusker
May 21, 2004 08:24 PM
typer_801
Feb 5, 2003 01:12 PM
Eluzion
Dec 8, 2002 10:33 PM
geminis2k
Dec 7, 2002 05:17 AM
