Need help asap! Oil return line!
Old Apr 8, 2005 | 05:35 PM
Civicman86's Avatar
Default Need help asap! Oil return line!
Ok so the fitting is like lower than the fitting I had put in the oil pan. I cant seem to get the line long/short enough to make the oil pan want to go back on. HELP PLEASE
BTW I know the fitting is not on tight at the top its beucase I got sick of taking it on and off like 100 times and didnt want to put it back on just for a pic.
Old Apr 8, 2005 | 05:48 PM
DurboDug93's Avatar
Default Re: Need help asap! Oil return line! (Civicman86)
Can you maybe clock your turbo to get the line up a lil higher? Thats what i had to do
Old Apr 8, 2005 | 06:05 PM
spoolin4door's Avatar
Default Re: Need help asap! Oil return line! (DurboDug93)
For a quick fix use a rubber hose and barb fittings
Old Apr 8, 2005 | 06:18 PM
Civicman86's Avatar
Default Re: Need help asap! Oil return line! (spoolin4door)
more pic
Old Apr 8, 2005 | 06:35 PM
nsxmatt's Avatar
I had the same problem. This is how I fixed it....
Stan's return kits are pretty useless with a ramhorn style or low hanging turbo.
Old Apr 8, 2005 | 06:44 PM
Finland's Avatar
you can get this done, believe me. It's just a matter of using the right combination of fittings. It is not necessary to use fancy anodized ones, you can get zinc oxided steel fittings very cheaply at your local Parker, or hydraulic supply house. Go there and look at their fitting selection.
Old Apr 8, 2005 | 08:16 PM
CRXLST's Avatar
Default Re: Need help asap! Oil return line! (Boondock Saint)
I used the 45 degree copper fitting at the oil pan.. Worked like a charm
Old Apr 8, 2005 | 08:25 PM
Wideopentuning's Avatar
I had the same issue on my Miata. I ended up sanding down the raised threaded portion of the drain flange and also cutting a -10 male fitting flush at the nut then welded the two. I gained an inch of oil drain height and made my life a lot easier. I still use a 90 off the drain fitting though.
Old Apr 8, 2005 | 10:03 PM
Full-Race Javier's Avatar
maybe try one of these...
find it here
Old Apr 9, 2005 | 07:48 AM
Civicman86's Avatar
Default Re: (Full-Race Javier)
Thanks for the replies guys. Im going to try to NSXmatt style right now. 2 reasons, its sat, I cant get to many of the fittings since most places are closed. And also the barb sitting is very small and will help get the swoop on the line.
Type-ARR
Nov 8, 2007 04:22 AM
Boosted_Coupe
May 20, 2007 12:15 PM
Anti-Drama Queens
Jan 10, 2007 06:27 PM
k20em2
Oct 19, 2006 07:24 PM
RATEDR
Jul 1, 2002 09:00 PM
