Is my oil return line angled TOO high?
Old 07-01-2002, 01:24 PM
RATEDR's Avatar
Default Is my oil return line angled TOO high?
My tech says the oil wont drain right because 1. the Earls fitting goes up at too high of an angle and 2. the hole isnt drilled high enough in the oil pan?
What do you all think?
The pic was taken at an angle so its not THAT drastic of a upward degree in to the oil pan.
Pics from the turbo side.
[Modified by RATEDR, 5:29 PM 7/1/2002]
another pic
[Modified by RATEDR, 5:52 PM 7/1/2002]
Old 07-01-2002, 01:50 PM
turboex's Avatar
Default Re: Is my oil return line angled TOO high? (RATEDR)
Looks fine, mine is the same way and i have had no probs
Old 07-01-2002, 01:51 PM
ninesecrx's Avatar
It looks fine to me. I dont know how big you drilled the hole in the pan, but the return line looks ok. If you ever check out steph. p.'s car, his return line is almost level. Also, if you look at a stock turbo VW...their oil return lines are low in the oil pan. I do think the higher the better though.
[Modified by ninesecrx, 10:53 PM 7/1/2002]
Old 07-01-2002, 01:58 PM
niedejb's Avatar
Default Re: Is my oil return line angled TOO high? (ninesecrx)
Its going to drain as high as the level of oil in the pan. If the oil is 1" above where your new hole is, you will have one inch of oil in your return.
This still leaves >18" for the oil to drain out of the turbo unrestricted.
Old 07-01-2002, 02:21 PM
CovertFI's Avatar
Default Re: Is my oil return line angled TOO high? (niedejb)
as long as the turbo is higher than the oil pan i know for sure you will have no problems
Old 07-01-2002, 02:44 PM
Etylorcen's Avatar
Default Re: Is my oil return line angled TOO high? (CovertFI)
Any more pix of your closed loop set up?
GSRwBOOST's Avatar
Default Re: Is my oil return line angled TOO high? (turboex)
ditto.. no problems yet...
Old 07-01-2002, 02:46 PM
HXMan's Avatar
LOL...mine used to look exactly like that except I had a flat run for about 3". I did the same thing as you at the turbo...just slipped the braided hose over the brass fitting. Now I have a 1/2" NPT 90 threaded into the flange, and a 45 fitting off that. Here are some pics.
Oh, where did you get the flex pipe that fit your WG dumpdube?? I NEED some!
[Modified by HXMan, 5:47 PM 7/1/2002]
Old 07-01-2002, 03:49 PM
PrecisionH23a's Avatar
Default Re: Is my oil return line angled TOO high? (HXMan)
i recommend shortening the line, make it look like HXman's
Old 07-01-2002, 07:12 PM
dextR's Avatar
flexpipe is courtesy of Pep Boys and some high temp flat black paint
nice fittings, looks very clean
[Modified by Thundarr, 11:15 PM 7/1/2002]
Old 07-01-2002, 09:00 PM
willyboyK20's Avatar
another pic
did u drill the fitting into the oil pan or had it welded?
Muckman
01-11-2004 10:12 AM
incogNitto
01-22-2003 08:46 PM
The_Head
12-13-2002 02:13 PM
shamoo
10-29-2002 11:08 AM
racerxadam
05-22-2002 03:20 AM
Quick Reply: Is my oil return line angled TOO high?
