Need help ASAP LSV-T
Old Apr 20, 2009 | 03:29 PM
EFhothatch15's Avatar
Default Need help ASAP LSV-T
i have a built ls vtec turbo i acquired second hand when i got the car i was told the tune was way off so i didnt run it i finally got a base map so i could run it to get tuned and the car runs like SH*T it wont idle and will not go over 3k rpm, long story short i found the gm 3 bar wired wrong fixed that and it still runs like poo but will go over 3k and back fires and blows black smoke PLEASE HELP.......
the base map is from phearable.net for all the modifications
Old Apr 20, 2009 | 03:34 PM
phaiwezzie's Avatar
Default Re: Need help ASAP LSV-T
a basemap is just someones guess-timate, tow it and get it tuned by a real tuner.
Old Apr 20, 2009 | 03:39 PM
yes i understand this but the nearest tuner to me is 3+ hrs i just wanna make sure the motor is strong enough. On a base map the car should still run correct?
Old Apr 20, 2009 | 06:13 PM
srmofo's Avatar
not if its blown up from being run with no tune
Old Apr 20, 2009 | 06:35 PM
Snafubmx234's Avatar
Check all of your basics. If I were you I would make sure that your timing is correct, all cylinders are firing, etc.
Black smoke = rich, typically. Do a compression/leakdown test to determine the condition of the motor. If that goes well tow to the nearest tuner.
Old Apr 21, 2009 | 03:31 AM
Topdawgg's Avatar
do you know what map sensor this "basemap" has selected?
do you have the same size injectors as this "basemap"?
if the answer is no to either of these questions, then its OBVIOUS why its running like ****.
every setup is different, every setup requires tuning even to get it to idle right. There are too many variables..
Old Apr 21, 2009 | 04:22 AM
thanks for all the help guys. The basemap was tuned for my map and injector size along with the other mods. I did do a compression test 175 170 175 168. I have the hondata s300 all ready i should just go get it dyno tuned and see if it blows up>.
Uknterror
Jun 14, 2012 09:16 PM
RedCd5TX
Engine Management and Tuning
13
Aug 7, 2009 10:44 AM
Civicman86
Mar 24, 2007 01:15 PM
crxzcracer
Mar 7, 2007 04:51 AM
OneSunkCivic
Jan 27, 2002 10:51 AM
