viper 500 and turbo timer help
Old Nov 22, 2002 | 10:39 AM
rbf351's Avatar
Default viper 500 and turbo timer help
everything is hooked and running, ut now the alarm won't arm itself after the turbo timer shuts off
is there any way of doing this?
if i don't use the turbo timer then it will arm itself
Old Nov 22, 2002 | 04:29 PM
Desslok's Avatar
Default Re: viper 500 and turbo timer help (rbf351)
use a relay to fake a ground signal to the door trigger wire until teh turbo timer shuts off
Old Nov 22, 2002 | 09:36 PM
TurboBumblBee's Avatar
ok im about to do this to my boys WRX w/ his viper800 alarm.. you can do a search and possibly find out another way but here are some ideas i have gathered from online and at work..
use a relay and follow this
85 ground
87a ignition wire one side (yellow on viper alarms)
30 ignition wire other side
86 turbo timer wire
Old Nov 22, 2002 | 09:39 PM
rbf351's Avatar
Default Re: viper 500 and turbo timer help (95CivicEX)
guess i'll try that tomorrow
cause i tried this way and it did nothing
85 : to ground.
86 and 87 linked together. These also go to key side of ign and the alarms ign input wire.
87a : turbo timer ignition sense / feed
30: engine side of ign. wire
A 1amp diode between 87 and 87a to provide 12 'sense' to turbo timer. Diode stripe to 87a.
Old Nov 23, 2002 | 06:06 PM
jdmotorsports's Avatar
dei makes a plug and play timer unit! ask your retailer about it. or you can use the remote start units and start it before you shut the ignition off. then it will shut off at what ever time you set the remote start to run.
[Modified by jdmotorsports, 7:09 PM 11/23/2002]
BrothaSit
Audio / Security / Video
Mar 2, 2012 11:13 AM
romoracing
Dec 6, 2008 10:49 AM
Syner-G-Racing LLC
Apr 24, 2008 01:33 AM
MRSI00
Aug 3, 2005 07:41 AM
FlatTire
Mar 23, 2004 04:42 AM
