n00bie turbo questions
Hey im trying to put a turbo kit together for my 91 integra and I just had a few questions. First off, I was planning on doing rods and pistons, but i was wondering if this would be pointless because i dont plan on resleeving the block. 2nd, My power goal is 250ish whp at around 9-10 psi, and i want to use a water+oil cooled turbo because its going to be a daily driver (for the summer), but im having trouble finding a turbo. I was looking at garrett t3/t4 and t3/t04e but but im not sure about the trim size and a/r that i should get to achieve my goal.
any help would be appreciated, and i have been searching on a few sites but i havent found exactly what im looking for.
thanks
`al
thanks
`al
Well, you are going to get a lot of search button comments but i'll try and help you out. Rods and pistons would be a good idea andyou don't need to worry about resleeving the block. You only need to do that wiht the h-series because that were made of a metal that would get f-ed up byt the forged internals. depending on the size of the turbo you go with, 250 hp should be very easily attainable with 9-10 psi out of a b18a. You could use a fairly small turbo and get away with that and still have a pretty low spool time. But really, you will be able to find a lot if you just search.
Re: (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip »</TD></TR><TR><TD CLASS="quote">The stock sleeves are very strong, much stronger than most give them credit for.</TD></TR></TABLE>
One hint of detonation at higher HP levels and they will blow though. As long as you don't detonate AT ALL this is very true
na its a b18a , its a stupid name because my friend was using my computer the other day and put his name on, so then when i went to switch back i forgot some of the numbers i had at the end, and i forgot the password so i just made a new name
