HELP! rebuild motor help needed
Old May 14, 2003 | 09:50 AM
Dorikamu's Avatar
Default HELP! rebuild motor help needed
JE Pro Series 9.2:1 CR Forged Pistons
Bored 0.020 over to 81.5mm
Darton stage 2 sleeves
Eagle ESP Forged Connecting Rods
ARP Rod Bolts
ARP Head Studs
Turbonetics T3/T04E Turbocharger (0.63 A/R Stage 3
turbine w/ 57 trim 0.60 A/R compressor)
Spearco Front Mount Intercooler
Drag Turbo Manifold
Drag Generation 3 Piping
HKS Super Sequential Blow Off Valve
Hondata s100
3 bar map sensor
RC Engineering 440cc Saturated Injectors
Crower 63402 Turbo Camshafts
Crower Valve Springs
AEM Tru-Time Cam Gears
Do I need to upgrade my valve to Ferrera? I want to build a bullet proof motor, is the stock vavle good enuf to run 15psi? Someone help please
Old May 14, 2003 | 09:51 AM
b18bturbo's Avatar
Default Re: HELP! rebuild motor help needed (chusai)
i would just get some portflow springs and with stock valves that should be pretty damn safe for 15psi for all out i would either get the rev valve springs and valves or the supertech with eibach springs
Old May 14, 2003 | 10:43 AM
Dorikamu's Avatar
Default Re: HELP! rebuild motor help needed (b18bturbo)
I just ordered the supertech valves from you guys, thanks!
Old May 14, 2003 | 10:44 AM
b18bturbo's Avatar
shipping out tommorw first thing. thanks the supretech works great by the way
jrp355
Feb 22, 2013 06:31 AM
LilCivic04
Dec 1, 2004 09:00 AM
Dorikamu
Apr 25, 2003 10:48 AM
Teg4e
Apr 22, 2003 12:24 AM
shamoo
Nov 3, 2002 03:13 PM
