Building an F22
Old Jul 11, 2001 | 07:35 PM
RH+G's Avatar
Default Building an F22
Okay I did my research and decieded that I want to be cool and get a turbo I know I need FPR, Pistons (JE), Rods, Head Studs (ARP) and a new head gasket. I will have a ignition system and a boost controller and fuel controller. I haven't decieded on which kit but it will more than likely be a DRAG. This is for My 94 Accord Ex. Am I forgetting anything that I need? I will only be boosting up to 12 PSI max. I will probably just stay at 8-10 PSI. Thanks
Old Jul 12, 2001 | 11:06 AM
DocF's Avatar
Default Re: Building an F22 (RH+G)
You dont need any of that crap to boost 12 psi track and 10 daily. All you need are some bigger injectors, a high flow pump, and a DFI. If you start to build up that engine you are looking at a $3000 minimum investment in parts and labor... and you will still need the other things i mentioned above.
Old Jul 14, 2001 | 12:12 PM
RH+G's Avatar
Okay I know that I should at least change the head gasket and the head studs just as a precaution. I'll get the injectors, DFI and pump and then I should be good to go. You saying I should be able to boost to 10 daily?
mels_ls_vtec
Sep 16, 2010 08:20 AM
D-meet07
Nov 4, 2004 06:29 PM
Wrath of VTEC
Sep 15, 2003 06:24 PM
ludesleep
May 30, 2003 02:54 AM
lazycoEX
Mar 10, 2003 03:04 PM
