on my quest for 500 need some help/advice
ok my engine is out on its way to getting built (h22 prelude chasis) i need some pointers.
1) first i need to ask about axles, who makes high hp axles for the prelude chasis?
2) i also need need adivce on a new turbo. before i was using a garrett t3/t04e, and i know that. that turbo tops out at like 350hp. so i need to go bigger. need some recomindations. preferable below the 1k price tag, and a 4 bolt exhaust side (dont want to cut the dp) then again not to worried about the dp
3) the infamous question. CLUTCH. i tried doing searches but it didnt help. preferably sprung i think
4)Injectors. i was thinking of going 1000cc just to have a little left over if i ever wanted more power. but idk. also what kind do i need. with my stock motor setup i was using the dsm 450's with the resistor box and the obd1 clips. i want to keep the same clips cause i dont remember where i threw my stock ones. so what injectors do i need for that.
ok i think that covers everything for now. thanks to everyone in advance
Mr. Badwrench
Re: on my quest for 500 need some help/advice (powerdbygarrett)
1 - drive shaft shop. 3.9's 5.9's if you are feeling froggy
2 - 35r
3 - competition clutch ask boosted jeff about stage
4 - 1000's are good. 1200's if you want to grow
2 - 35r
Re: on my quest for 500 need some help/advice (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">1 - drive shaft shop. 3.9's 5.9's if you are feeling froggy
2 - 35r
4 - 1000's are good. 1200's if you want to grow</TD></TR></TABLE>
the exact things i would have told ya
2 - 35r
is drive shaft shop an actual company or are u just refering to any drive shaft shp? also whats the diffrence between 3.9's and 5.9's
also what kind of 1000cc injectors do i need for the obd1 clips. will i still need the resistor box?
thanks
thanks
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett »</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
http://www.driveshaftshop.com
there is no better.
the difference, is hp / tq capacity, and about 600$ in price. you would need to call them or contact a dealer about fitting them to your lude.
or call NRG tech. thats where i got mine and big tom and miller gave me a great deal.
and as far as injectors, above 750's, you will need a resistor box anyway. i dont know of saturated injectors above that. i use rc, but precisions are just as good.
there is no better.
Mr. Badwrench
Re: (powerdbygarrett)
a good tuner should be able to get you 500 on 1000cc/min injectors. if you want room to grow into, then maybe 1200's. i think 1600's are a little overkill for now.
