is my oil pressure normal??
Old Jan 27, 2005 | 08:14 AM
coupon's Avatar
Default is my oil pressure normal??
autometer oil pressure gauge
idle- 25
crusing with really light throttle (in low rpms 2000-3000)-45
crusing with a little more throtthle (in low to mid rpm's 3000-4500)-60
75% (4000-5500)- 65
Old Jan 27, 2005 | 08:17 AM
m R g S r's Avatar
Default Re: is my oil pressure normal?? (nlc)
throttle position doesn't make a difference for oil pressure. It's rpm dependant, because the pump is spun by the crankshaft.
Idle should be about 20psi and 3000rpm's should be about 60. Around 70-75psi when VTEC is engaged. . .
It would help if you told us the block, because VTEC pumps have a higher pressure. . .
Old Jan 27, 2005 | 08:20 AM
Rufus523's Avatar
I was told that at idle around 8-15 lbs. More importantly, you should have 60 lbs by 3k RPM. High oil pressure isn't a bad thing, as long as levels (cap.) are right etc. This is what I go by, anybody else?
Old Jan 27, 2005 | 09:26 AM
coupon's Avatar
Default Re: is my oil pressure normal?? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">throttle position doesn't make a difference for oil pressure. It's rpm dependant, because the pump is spun by the crankshaft.
It would help if you told us the block, because VTEC pumps have a higher pressure. . . </TD></TR></TABLE>
its a gsr
Old Jan 27, 2005 | 11:18 AM
b16h22a's Avatar
generally you want 10psi for every 1000rpm
Old Jan 27, 2005 | 11:19 AM
PM-Performance's Avatar
Default Re: is my oil pressure normal?? (b16h22a)
mine didnt go high. pressure was like 10-15 at idle and 50maybe 60 tops under hard load
Old Jan 27, 2005 | 11:33 AM
fjt's Avatar
fjt
At start up cold--&gt;80-82PSI
Warmed up----&gt; 20-22psi
After a few heat cylcles or being running for some time it stays between 10-15 at iddle (iddle at 8-900rpm)
Old Jan 27, 2005 | 11:35 AM
mrbsponge's Avatar
you should have roughly 15 psi for every 1000 rpms until pump maxes out of course
Old Jan 27, 2005 | 06:52 PM
coupon's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">At start up cold--&gt;80-82PSI
After a few heat cylcles or being running for some time it stays between 10-15 at iddle (iddle at 8-900rpm)</TD></TR></TABLE>
my idle is 7-800 and its only 60-65psi at max
so my #'s are ok?
Old Jan 27, 2005 | 06:54 PM
b16h22a's Avatar
Default Re: (nlc)
yea that is plenty also the weight of the oil will effect the pressure
Old Jan 27, 2005 | 07:05 PM
coupon's Avatar
Default Re: (b16h22a)
im running mobil1 syn. 10w30
Old Jan 27, 2005 | 08:17 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (nlc)
Im at like 85-90 @ WOT on my stock B20... is that to high? Im worried Ill blow the seals on my turbo once Im boosted...
Blaze
Old Jan 30, 2005 | 07:55 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (Blaze45)
Anyone have an idea?
Old Jan 30, 2005 | 08:13 PM
W O T's Avatar
Run a restrictor on your feed line, run smaller line
Old Jan 30, 2005 | 08:29 PM
leadfoot78's Avatar
Default Re: (W O T)
80psi on start up, 25psi on warm idle, 80psi by 3k, 85psi max. I'm using regular Castrol GTX 10W30. I'm also using a .080 restrictor and a -4AN line, no blown seals and now leaks at all.
Old Jan 30, 2005 | 08:47 PM
W O T's Avatar
Default Re: (leadfoot78)
Im gonna run a 3an line and the end of my fitting for my feed is narrow as ****, maybe 1/8" inner diameter
Old Jan 30, 2005 | 08:50 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (W O T)
How much pressure does the turbo need? I wouldnt think more then 50 psi or so would it?
Old Jan 30, 2005 | 09:46 PM
W O T's Avatar
I turbo would be plenty happy with 10psi, Id say 50psi would hurt it, thats why I thought most oil line kits are 3an line..... I dunno, I know they dont need much though
Old Jan 30, 2005 | 10:20 PM
leadfoot78's Avatar
Default Re: (W O T)
oops, u are right i have a -3AN line, my mistake
Old Feb 7, 2005 | 01:03 PM
Rod.'s Avatar
start up 75psi
warm up 30 psi
then a few mins later in idle it drops down to 10psi
hard driving 60-65psi
Does that sound kind of normal
Old Feb 7, 2005 | 04:17 PM
Gsr_Hybrid_theory's Avatar
Default Re: (redturbocivic)
if it makes u feel any better... in an 04 nsx idle... the damn guage BARELY moves... and like 5k its like 30ish and at 8... meer 60-70 lol.
when i drove it out of the shop to gas it, i looked at the guage and freeked out... then was told "its normal for oil pressure to be minimal" i dont like that
trulyshavedintegra
Dec 9, 2012 05:06 AM
sasinorm01
Nov 21, 2006 07:26 PM
Harassing Herbs
Mar 16, 2004 05:09 PM
Audipwr1
Jul 18, 2003 02:37 PM
MIKES
Jun 5, 2003 11:26 AM
