code 73...
Old Sep 16, 2004 | 01:49 AM
encognito's Avatar
Default code 73...
cylinder 3 misfire or a random misfire a condition is .creating a cylinder mifire.
Any lamens terms to what this means and/or what i should do about this?thanks
Old Sep 16, 2004 | 05:41 AM
sneakychaos's Avatar
Default Re: code 73... (encognito)
Could be a lot of things, best bet is to try the "Tech Forum".
Old Sep 16, 2004 | 06:24 AM
Dogginator's Avatar
Daisy... Daisy...
Misfiring injector, fouled spark plug, low compression, bent valves, bad plug wire...
Check you wire connections (fuel injector and spark plug wires) and do a compression check.
Old Sep 16, 2004 | 12:11 PM
encognito's Avatar
Default Re: code 73... (Dogginator)
I've done a compression test and it barley reads anything in that cylinder
Old Sep 16, 2004 | 12:15 PM
encognito's Avatar
Maybe i should say what i did...
I red lined 3rd. and dropped it into 2nd, but as soon as i let out the clutch (not sure if i let it out completely) i pushed it back in...
Now when i turn it over it sputters and eventually dies
Old Sep 16, 2004 | 12:24 PM
Mugen Mike's Avatar
Definitely sounds like bent valves
Old Sep 16, 2004 | 12:56 PM
encognito's Avatar
Default Re: code 73... (Mugen Mike)
Let me ask this then. Do you think i should replace them with oem vavles, or what are some good aftermarket valves ?
Old Sep 17, 2004 | 04:40 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by encognito &raquo;</TD></TR><TR><TD CLASS="quote">Let me ask this then. Do you think i should replace them with oem vavles, or what are some good aftermarket valves ?</TD></TR></TABLE>
It's debateable. How high do you wish to rev? I installed ITR inake valves and titanium valve spring retainers (6 grams per valve) on my head for a 9000 rpm limit. Go with aftermarket if you want a slightly higher compression. However, aftermarket valves will not help you if you repeat that misshift.
Old Sep 19, 2004 | 06:28 AM
BudMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
It's debateable. How high do you wish to rev? I installed ITR inake valves and titanium valve spring retainers (6 grams per valve) on my head for a 9000 rpm limit. Go with aftermarket if you want a slightly higher compression. However, aftermarket valves will not help you if you repeat that misshift.</TD></TR></TABLE>
DOH! exactly!!
thunderboy
Apr 24, 2010 08:39 AM
B18CivicHatch
Aug 24, 2007 12:13 AM
themex77
Feb 17, 2007 02:29 PM
bmiller17
Apr 2, 2006 01:57 PM
project142
Jan 28, 2004 06:06 PM
