My ls project
Old Dec 5, 2009 | 12:17 PM
  #276
ls_on_boost's Avatar
Default Re: My ls project
Originally Posted by Matt93eg
I'm in for the video bro. Get one done soon!!!
lol will do
Old Dec 5, 2009 | 04:06 PM
  #277
sh!ft's Avatar
Who the fack changed my title?!
Originally Posted by ls_on_boost
nice runs. seems like you had the right idea on the 2nd run.
what was that squeaking? a belt or just something plastic rubbing inside the car? you are running a sprung clutch correct? seems like you still have a little shake here n there/every now n then. i DID catch that around the 2nd burnout. seems like the car is still lacking power somewhere. mabey a good pn and some cams will clear it all up. are you running stock throttle body?
all in all nice work so far man. mad props.
Old Dec 5, 2009 | 07:57 PM
  #278
any nosie is from the inside of the car vibrating.yes its a spring clutch.what do you mean a shake here and there?the car doesn't lack power im not power shifting and yes im running a stock throttle body
Old Dec 6, 2009 | 03:54 AM
  #279
Silva Bullit DC4's Avatar
I heard it too. Sounds more like a "scratch". Heard it when he was switching lanes in the 2nd run.
Old Dec 6, 2009 | 12:20 PM
  #280
sh!ft's Avatar
reason i say "shake" is because i saw the dash move a little bit(or at least i saw it shake a little bit) hence the reason why i asked if you had a sprung clutch, because my friend had an unsprung one and his car tended to jump/shake a little bit at take off.
no negativity intended
Old Dec 6, 2009 | 12:21 PM
  #281
sh!ft's Avatar
i keeell you!!!! lol avatar
Old Dec 6, 2009 | 12:59 PM
  #282
LOL yup, thats my boy right there!
Old Dec 6, 2009 | 08:21 PM
  #283
its my back plastics in my car my motor does not make any nosie i use to have bass in the car and now everthing rattles when you drive or when the car is on
Old Dec 7, 2009 | 03:41 AM
  #284
lol
Old Dec 7, 2009 | 07:35 PM
  #285
n008i3's Avatar
All i can say is WOW!!! I too am currently building a ls-t. Your build just makes me wanna build mine even more. I am currently machining my block and head myself at school. I was debating weather to sleeve the block or not, but i think 20lbs should be plenty for me. keep up the nice work.
Old Dec 8, 2009 | 02:04 AM
  #286
thanks i think its worth it to sleeve the block you always want more boost lol
Old Dec 12, 2009 | 09:49 AM
  #287
http://www.youtube.com/watch?v=Hlcf_cb_T7Q
Old Dec 18, 2009 | 03:28 PM
  #288
Rease3's Avatar
omg i love how ur exhaust sounds 3" turbo back? nice number on 21 psi. u get cams yet? u going to rebuild the trans?
Old Dec 18, 2009 | 07:09 PM
  #289
thanks 3inch open downpipe naw no cams yet im thinking of going vtec not sure and im gonna get a gsr trans im in the process of working out a deal on one and i'll sell this b16 trans i don't know whats wrong with 4th
Old Dec 18, 2009 | 09:03 PM
  #290
cslegacy's Avatar
just read hole thing, nice man. i wonder wat times ur running
Old Dec 23, 2009 | 04:16 PM
  #291
Jenzo's Avatar
Just read all 12 pages very nice mad props yo.
Old Dec 25, 2009 | 02:45 PM
  #292
thank you sir and merry christmas to all
Old Feb 8, 2010 | 11:42 AM
  #293
changed boost in first and second 1st is now 14psi and second is 22psi like 3rd 4th and 5th but gotta go to a real track maybe friday i can go to a better track
http://www.youtube.com/watch?v=MRg4ZvLA4vA
Old Feb 8, 2010 | 12:44 PM
  #294
Mutiny1's Avatar
arent u worried you will blow ur block? aiming for power that high and spending all that money in parts id make sure your block can handle it or not risk wasting all that dough. thats just IMO.
Old Feb 8, 2010 | 12:49 PM
  #295
my bottem end is built just stock sleeves
Old Feb 8, 2010 | 05:40 PM
  #296
boostedeg302's Avatar
Nice build man. The shake you talked about is nothing wrong with the tranny, it is from the stage 4 clutch that you have. If not slipped just perfectly, the car will tend to shake. Mine did the same thing when I first finished it. Looks like all you need now is to perfect your driving. It takes a lot of seat time to get full advantage of all that power. I had a stock ls vtec with ebay kit on 10psi go 11.71 at 118 in an eg hatch with 23inch m&h's and stock diff, mounts, etc. Your **** should fly once you dial in your driving
Old Feb 8, 2010 | 05:45 PM
  #297
btw do you do 1st or 2nd gear burnouts? My car really started to hook when I did 2nd gear burnouts
  #298
Turbogixxer's Avatar
Very nice burnouts!!!!
Need a better track :p
Old Feb 8, 2010 | 06:46 PM
  #299
kte324's Avatar
Your car is well put together.
Old Feb 8, 2010 | 07:04 PM
  #300
thanks yeah i read some where about the chatter and yes i do 2nd gear burnouts
