My gauges are messing up....HELP.
Old Mar 3, 2003 | 10:38 PM
blufke's Avatar
Default My gauges are messing up....HELP.
Well after adjusting my timing belt(so nice and tight now) i went out for a drive and i rapped it up and then after a little while noticed the monster tach wasnt lit up or working and neither was my oil press. or temp gauge. They do this(weird): when the lights arent on the light up dimly for a while then slowly go out while sort of functioning(kinda jumpy), but when i move to just parking lights or headlights they completely shut off. any ideas?
Old Mar 3, 2003 | 10:56 PM
Flamenco-T's Avatar
Default Re: My gauges are messing up....HELP. (blufke)
so the timing belt is all good and nice now ? good
you prolly have a short or on and off shortage...check your 12V wires and ignition too if you tap it to the ign wires (greddy and etc)
stan
Old Mar 4, 2003 | 09:10 AM
blufke's Avatar
Default Re: My gauges are messing up....HELP. (Flamenco-T)
stan
yes its toight, toight like a toiger. any other ideas on the gauge problems?
Old Mar 4, 2003 | 09:13 AM
Flamenco-T's Avatar
now this is only the light part right ? the gauges needles works properly ?
Old Mar 4, 2003 | 11:50 AM
blufke's Avatar
when headlights/parking lights are on the needles dont work either.
Old Mar 4, 2003 | 12:51 PM
TurBoTeG's Avatar
I had a similar problem. check all your connections (ground/power/dimmer)...my tach light would go on when the lights were off...then go off when i turned the lights on...and the tach liked to bounce around sometimes
[Modified by TurBoTeG, 1:57 PM 3/4/2003]
Old Mar 4, 2003 | 01:00 PM
BROOD's Avatar
Default Re: My gauges are messing up....HELP. (TurBoTeG)
When you originally wired up the gauges did you use separate power/ground for the illumination and gauge power? I've seen gauges act in that manner when the dimmer power/ground are used for the gauge power as well. Perhaps a bad connection or short to ground???
I'd recheck you gauge wiring harness and see what is going on.
[Modified by SLPR, 2:02 PM 3/4/2003]
Old Mar 4, 2003 | 05:10 PM
blufke's Avatar
Default Re: My gauges are messing up....HELP. (SLPR)
they came that way on the car. and the post right before yours is exactly the problem. i guess ill go through all the connections.
Old Mar 4, 2003 | 06:03 PM
mechanik's Avatar
check all grounds yo!
Old Mar 4, 2003 | 11:06 PM
blufke's Avatar
any special advice? i checked grounds and power and they seem good.
Old Mar 5, 2003 | 09:22 AM
Pengo's Avatar
where are you tapping for power? and what grounds are you using? pics?
Old Mar 5, 2003 | 05:27 PM
blufke's Avatar
Default Re: My gauges are messing up....HELP. (Pengo)
well, i think when i was messing around with the connectors and such and removed the connector supplying the voltage, i may have not put it in the proper place. anyone know which one supplies the right voltage(guessing 12v)? how does that ground look?
supply(red wire):
ground(black wire):
Old Mar 5, 2003 | 06:16 PM
B18EG6's Avatar
hey man this will save you a huge headache...see those ports next to the fuses, with nothing in them? thopse can be used for supplying power to various things...lemme dig up my picture that i made.
EDIT here...see the way i dd it? its WAY easier. The white one is the one that gets the 12v power when the lights are on...the red one is the one that gets the 12v power when the IGN switch is on.
[Modified by B18EG6, 10:18 PM 3/5/2003]
Old Mar 5, 2003 | 06:18 PM
Pengo's Avatar
how is the red supply wire attached? is there a fuse there and its shoved in with it or you have some type of connector? ( i cant really tell from that pic and angle)
for the ground, where does that bracket lead to?
are your gauges all elec. or is it just to power the lighting? how many gauges? you have them all powered and grounded through that same single wire?
Old Mar 5, 2003 | 06:29 PM
blufke's Avatar
3- 2 1/16th gauges and the monster tach off the one power and all grounded on the same.
B18EG6's Avatar
Well you put a solderless crimp on the end...female spade type...and push it into the fusebox, real easy.
I have all electrical gauges, and I have a nice thick ground wire going from a solid ground to a junction where all the other grounds come.
Currently I have boost gauge, egt, and fuel pressure gauge...ground can be single wire, as can power for lights and ignition, just make sure you FUSE them!
Old Mar 5, 2003 | 06:42 PM
khang77642's Avatar
Default Re: My gauges are messing up....HELP. (B18EG6)
cool, I will be doing that nextime.
Old Mar 5, 2003 | 06:46 PM
Pengo's Avatar
haha my fault for the confusion man, i was askin blufke to see if maybe it was a case of bad connection or bad ground. yea i'm tapped into a coupla spade connections for my gauges and tt. you have an inline fuse with your setup?
Old Mar 5, 2003 | 06:51 PM
B18EG6's Avatar
no worries...yes i have inline fuse for almost anything i wire. made my own fusebox
Old Mar 5, 2003 | 07:57 PM
Integra_Boi's Avatar
New User
hey i did the same way with my turbo timer.. the only wire i'm short is the ignition wire.... where does that go? i did the 12constant and 12v accessory all on those house looking plugs
Old Mar 5, 2003 | 08:50 PM
accordfreak's Avatar
how do you dtermine what kind of fuse to use?
Old Mar 5, 2003 | 09:56 PM
B18EG6's Avatar
Default Re: My gauges are messing up....HELP. (accordfreak)
I used a 5 amp fuse...one for 12V ign, and one for 12V lighting...
is that right? I figure 5 amps divided amoung 3 gauges is enough
Old Mar 6, 2003 | 12:10 AM
blufke's Avatar
apparently it was a crappy *** ground on that little metal bracket, it only touched the body/frame on a painted surface. Moved it to a nice contact and Voila. Still need to add that fuse, but thanks for all the help!
now i have this hesitation problem(very doubtful its gauge related, but i guess somehow it could be possible, but i dont see how):
https://honda-tech.com/zerothread?id=434427
Old Mar 6, 2003 | 10:44 AM
Pengo's Avatar
yea thats why i was askin about that bracket. couldnt tell where it led to from the pic. well, i'm glad you got it fixed. good luck with your car man
Casey Smith
Honda Civic (2001 - 2005)
Nov 20, 2017 02:32 PM
OGCRV2001
Honda CR-V & Element
18
Feb 12, 2015 11:54 AM
wideload
10
May 28, 2010 10:26 PM
h23prelude94
Sep 1, 2008 08:59 AM
f22kid
Mar 17, 2008 06:06 PM
