My fuel setup: is an adjustable FPR needed?
Old Oct 30, 2002 | 06:50 PM
Precision DC4's Avatar
Default My fuel setup: is an adjustable FPR needed?
I know this topic has been covered many times, and I have searched, however there is rarely a difinitive answer.
So with that said, here's my question:
I plan on running a t3/60-1 turbo, 440cc RC injectors, a walbro 255lph fuel pump (NOT high pressure), and Hondata to tune it all. My question is, does Hondata negate the need of a fpr to regulate fuel pressure? Or does the higher flowing walbro fuel pump create the need for one?
TIA
Old Oct 30, 2002 | 06:59 PM
ion_four's Avatar
Default Re: My fuel setup: is an adjustable FPR needed? (BlackIntegraLS)
Use your stock regulator unless you are topping out your injectors (over 250-300hp, depending). In that case, you should just get larger injectors.
...Next?
Old Oct 30, 2002 | 07:08 PM
tygsr's Avatar
Default Re: My fuel setup: is an adjustable FPR needed? (ion_four)
Personally I would go with a 1:1 fpr for that kind of setup.....
Old Oct 30, 2002 | 07:59 PM
Default Re: My fuel setup: is an adjustable FPR needed? (tygsr)
a stock honda fpr is 1:1, correct?
Old Oct 30, 2002 | 09:21 PM
skilzz's Avatar
The whole point of getting even a cheap B&M 1:1 is because its adjustable. If its a turbo car it is nice to have so you can adjust fuel pressure and the little gauge that goes with it serves a good purpose also. anyways, according to http://www.hondata.com they want you to set the fuel pressure at 60psi...you can't do that with a stock one.
I suck at posting links, go to s200 under products then click boost, its underlined in the list of features.
[Modified by maddskilzz, 1:24 AM 10/31/2002]
[Modified by maddskilzz, 1:25 AM 10/31/2002]
[Modified by maddskilzz, 1:27 AM 10/31/2002]
Old Oct 30, 2002 | 11:35 PM
*Boostwerks*'s Avatar
no.
a Stock Honda FPR is 1/2:1
Aeremotive will do you nicely.
Or if you don't want An lines I would go with a AEM.
Old Oct 31, 2002 | 04:31 AM
RGAZ's Avatar
New User
Be aware the 255 pump will overload the FPR and it won't bypass enough fuel to allow a pressure under 40psi.
You may want the fpr just for that alone.
Randy
Old Oct 31, 2002 | 04:38 AM
symba's Avatar
Default Re: My fuel setup: is an adjustable FPR needed? (RGAZ)
[QUOTE]Be aware the 255 pump will overload the FPR and it won't bypass enough fuel to allow a pressure under 40psi.
[/QUOTe}
yeah, you may want to get an FPR
Freemananana
Feb 22, 2014 03:40 PM
golf-mk3
Oct 7, 2010 05:27 AM
endlessdv
Jan 9, 2006 12:47 PM
redline201
Feb 6, 2003 08:02 PM
