my engine and turbo alot louder now after i put in mobil one oil is that normal??
using mobil one 10-30
Re: my engine and turbo alot louder now after i put in mobil one oil is that normal?? (u2civic1)
It should be normally when you change the oil in your car your giving it back its performance in horsepower cause your changing it from the old oil. Hence giving you back the horsepower that you lost from the dirty oil that was robbing it. Its your car tellin you thanks it really needed that whens the last time you changed it.
Aslo check around the area just incase dont wana second guess yourself yaknow. BUt didnt you notice a big difference in the oil change like an added extra kick.
Re: my engine and turbo alot louder now after i put in mobil one oil is that normal?? (preluder)
i had an oil change like 2weeks ago when i got the turbo in so it was new
the car feels alot better and it spools alot faster it just makes some noises that i didn't expect
even the spooling is alot louder too
Modified by u2civic1 at 8:48 AM 8/10/2003
New User
I really recommend going with the Mobil1 15w40 instead I think you'll agree after you make the switch
Re: my engine and turbo alot louder now after i put in mobil one oil is that normal?? (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail »</TD></TR><TR><TD CLASS="quote">I really recommend going with the Mobil1 15w40 instead I think you'll agree after you make the switch</TD></TR></TABLE>
Would you mind explaining the pros and cons of a thicker oil? I felt a noticeable difference going from 5w30 to synthetic 10w30, I burn far less oil and the car just seems to drive smoother, can I expect similar gains switching to synth 15w40 in a moderate climate on a mildly boosted LS(Seattle weather and 7 PSI on a T3/T04E)?
Thanks!
Thanks!
Re: my engine and turbo alot louder now after i put in mobil one oil is that normal?? (mskibbz-T)
the turbo creates so much more heat that the oil thins out more than normal so a lower viscosity, heavier weight oil is better to use.
Re: my engine and turbo alot louder now after i put in mobil one oil is that normal?? (Redlineracer)
makes sense to me... same idea as recommending different oils for different climates, the turbo related heat just makes it the damn sahara under our hood.. thanks
return_2020
11
01-05-2005 05:42 AM
