My EM1 Build
Hey guys just seeing what you guys think will be a reasonable power for me to hit. It will be going into the shop tomo for a couple things then be getting tuned and dyno couple days later. So just seeing what you guys think it will hit so I know kinda what to expect. Here is some specs.
Engine
Integra Type R Head*
Super tech valves springs and retainers
Civic Type R Cams
Skunk2 Pro series Cam Gears
84MM B18c1 Engine*
Golden Eagle Sleeves*
9:1 Arias Pistons*
Eagle Rods
S300
Catch can
Victor x manifold
70mm Omni Throttle Body
R.C. Engineering 750cc Injectors( what's going to limit me)
AEM Fuel Rail
Walboro 255lb Fuel Pump
*Precision 750 HP inner-cooler *
NSR ramhorn manifold
Precision 62/62 billet turbo*
Full 3" skunk2 exhaust
ARP head studs, main studs*
ACL bearings
B16 Transmission*
Competition Stage 5 with flywheel combo*
Somethings there I know I'm going to be limit on fuel. But let me know what u have seen, or have done. Comments welcomed. Thanks guys!!
Engine
Civic Type R Cams
84MM B18c1 Engine*
9:1 Arias Pistons*
Eagle Rods
S300
Catch can
Victor x manifold
AEM Fuel Rail
ACL bearings
B16 Transmission*
Awesome thanks so no reason why it shouldnt hit 450+ then. Thanks for all the input, now when time come should I go with another walbro? Should I go bigger than 1000cc IDs injectors?
1 Walbro is plenty enough until you start looking at some crazy amount of power.
For over 500whp I would recommend ID1000's. They are the best injectors out right now, idle fantastic and are able to give you plenty of room to play with.
And at $450, they are a steal
Deucedeuceteg
28
May 23, 2007 06:00 PM
