horse power questions???
i was wondering what kind of horsepower i will have. all i have to do is put it together i have all parts. here is the list:
ross 84mm 8:5:1 pistons
moly rings
eagle h-beam rods
darton sleeves
aem fuel rail
skunk2 pro series intake
walbro 255lph fuel pump
jge ss valves .5mm over size
jge dual valve springs
skunk2 cam gears
65mm trottle body
fidanza aluminum flywheel
rc 1000cc injectors
obx stage 3 cams
all race bearings
garette gt35r turbo
i think thats all i feel like im forgetin something.
well let me know what u think.
moly rings
eagle h-beam rods
darton sleeves
aem fuel rail
skunk2 cam gears
65mm trottle body
rc 1000cc injectors
obx stage 3 cams
all race bearings
garette gt35r turbo
Re: horse power questions??? (THC07)
are u serious i had 315hp to the ground with a good tune, skunk2 intake, turbo and injectors. before i started to build it
Re: horse power questions??? (fast92hatch)
hmmm, well dont listen to me, i dont pay much attention to forced induction, i like the NA myself.
maybe you will get around 600 like your sig, but i dont think so.
Ek Forever y0!
It's so hard to give you even a semi-accurate answer. I'm sure you're anxious to find out. Just wait until you get it tuned.
I could guess, but to feel confident I'd have to say 400-500 whp.
Ek Forever y0!
Re: horse power questions??? (redcoats1976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcoats1976 »</TD></TR><TR><TD CLASS="quote">im not a honda wizard but i think it might go BOOM sooner than you would like.</TD></TR></TABLE>
Then don't post, because It won't go boom with that build and a good tune.
Re: horse power questions??? (ek forever guy)
will that sounds convencing. ill try 25psi and work my way up. i might start lower giving time for the motor to break in.
Re: horse power questions??? (doood)
definitely a better fuel system what size pump and injectors are you running? what engine management will you be running?
Your horsepower will only come from how well it is tuned. 30 psi for the streets might be a bit much, and not very comfortable to drive I would think.... A 350-400 horsepower street civic would dominate pretty much anything in the streets, as long as the traction is there.... good luck
the GT35R usually runs out of juice around 28psi ... Unless you have a really good tune... My buddies MR2 made about 440whp on 26psi on his GT30R...
Now is you GT35R a new version or the older one... Post pics then I can for sure tell you what generation it is... I use to sell Garrett turbo chargers on the side...
Re: (ke98248)
it will be a custom tune. same guy as last time. he did an awesome job. did it while driving instead of a dyno tune. but its a walborn 255lph pump w stock lines. and 1000cc injectors. everything should be listed on the first post.
Re: (jarvis199)
why is that. i figured a street tune would be beter for it. its not a programer. the guy hooked up his computer to the car. sat in the passanger seat while i was driving 4th gear wide open. it woke it up a lot the first time.
