my dyno at payn tech.
Old Sep 10, 2003 | 08:04 AM
  #26
maddog20's Avatar
Default Re: (platinum00)
When payn sent me there base map it was super duper rich and it clogged my cat. This caused a really slow spool up. I switched to a test pipe and it made big difference in spool time and I bet you'll gain a pound or two in boost.
When you first got on the dyno did you have alot of black smoke out the exhaust?how many miles on car? how long did you drive on the base map?
Old Sep 10, 2003 | 08:15 AM
  #27
platinum00's Avatar
Default Re: (maddog20)
i had mad smoke. i straight thought my engine blew. hehe.
no smoke now.
the engine has about 4k on it. i was driving on a ks-motorsports basemap for 2 weeks maybe, never hit boost though.
i have a high flow cat. but im still running my small exhaust and the tiny sohc downpipe.
platinum.
Old Sep 10, 2003 | 08:27 AM
  #28
Finland's Avatar
Default Re: my dyno at payn tech. (platinum00)
3 inch turbo to tip, get rid of the cat, or run a 3" hi flow. Exhaust diameter absolutely makes a difference on turbo cars. Also, it should all be mandrel bent, and never reduce diameter! Keep it the same diameter all the way through.
Old Sep 10, 2003 | 08:31 AM
  #29
platinum00's Avatar
Default Re: my dyno at payn tech. (acurate1)
i was thinking 2.5 inch downpipe and 3 the rest of the way. only reason i say that is i dont have room for a 3. i dont think i have room for 2.5 hehe.
so this will increase my spool time and give me power. whooaaa.
Old Sep 10, 2003 | 08:38 AM
  #30
TotalJDM.com's Avatar
Torque looks pretty good
Andre
Old Sep 10, 2003 | 03:59 PM
  #31
Finland's Avatar
I know that it's possible to go 3" from turbine all the way back, because I have done it, and retained air conditioning (although now it's removed) You will however have to fabricate the downpipe like I did. It will not hurt you too tremendously to have the initial bend in 2.5" instead of 3" but the bigger the better. Keep in mind that you want a large pressure differential between gas inside the turbine and gas outside, this propagates flow. Ideally you would have zero pressure outside the turbine. Good luck.
Old Sep 10, 2003 | 04:09 PM
  #32
platinum00's Avatar
i dont have a/c so hopefully i can do it. so you have a sohc greddy kit with a 3 inch dp. are you getting any spiking. what psi are you running. what are you numbers and when is full boost.
sorry for all the >???'s
platinum.
Old Sep 10, 2003 | 04:25 PM
  #33
Finland's Avatar
no it's a RevHard kit, I run 10psi at the strip. I will not have dyno numbers until I go Hondata this winter, I will have Payn tune mine too when the time comes.
manifold pressure goes positive at 3000 at WOT, peak pressure is not reached until much much higher, I don't have an exact RPM for peak pressure. Keep in mind this is a T3/TO4e 60 trim turbo, which is a bit larger than the 18G I presume is in your kit. A friend of mine runs the Greddy kit on his GSR and it spools much quicker than mine, but mine makes up for it in the upper end.
Old Sep 10, 2003 | 04:59 PM
  #34
platinum00's Avatar
**** i only have 15 g. ;(, yea im sure you will be putting down some nice numbers with that turbo..
i have the manifold for that sitting in my room. i cant decided if i want to blow my motor up or not. hehe
platinum.
Old Sep 11, 2003 | 05:40 AM
  #35
platinum00's Avatar
here is a image
Old Sep 11, 2003 | 06:17 AM
  #36
trbob16a's Avatar
Default Re: my dyno at payn tech. (TotalBoost)
I would get a 3" exhaust and tune it at 15lbs. With that small of a turbo it should be fine at a bar.
Old Sep 11, 2003 | 07:23 AM
  #37
platinum00's Avatar
Default Re: my dyno at payn tech. (trbob16a)
sounds good , that's what i plan to do..
thanks for the input.
how long will that turbo last at 1 bar. like a week.
JTRO15
Honda Civic (2006 - 2015)
21
Apr 17, 2009 09:55 PM
Haleiwa-Brando
42
Apr 10, 2006 04:34 AM
aberkrombie
Aug 13, 2003 07:23 AM
fast[R]
Sep 20, 2002 01:40 PM
Purelude
Oct 26, 2001 07:54 AM
