my down2turbo turbo is fucked!!!
first state fired up my car with a down2turbo ebay t3 60 trim turbo....
with less than a mile on the freshly built engine... they heard a screeching noise and didn't know what it was and drove it back into the shop....
upon looking at the turbo, the shaft completely wobbles while SPINNING!!!
******* shitty turbos
dam sounds like to me they didnt run the oil right . or turbo didnt have enough oil to start on.. becuase they should have checked if there was shaft play before they installed it.
Re: (turboda6)
It does sound like thats the case - new setup, unused turbo. My guess you didn't prime the turbo by cranking it over until the turbo was definately filled. Even at low engine rpm's the turbo shaft is still spinning - they aren't exempt from the metal-on-metal rules motors are.
for everyone calling me a turbo noob...
first off this was done by a very reputable shop, who definately primed the turbo when they were cranking the car
I just did a search and found others that had down2turbo turbos go bad on them...
I guess I'm a noob since I had a turbo kit on my car for two years before this build
Re: (igo4bmx)
Does it still fall within the 90 warranty? I had a down2turbo take a dump on me last week. It started smoking really bad one day, i checked the shaft and found that it had become soo loose that the blades came into contact with the comp housing. It lasted me 3 months and no more than 3500 miles. My oil feed and oil drain are sitting pretty, i had taken every precaution while installing my turbo to make sure that it would not be due to an oiling prob. I even ran a ATP oil restrictor and all that bs. Ive heard that some people have had very good luck with MJM turbos, with a few receiving shitty ones.
oh well.... what can you do, right? time to upgrade.
my only prob is that my turbo is well out of the 90 day warranty.
Re: (turboda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboda6 »</TD></TR><TR><TD CLASS="quote">turbo noob. wasted a perfectly good turbo... dumbass</TD></TR></TABLE>
This is the 2nd time i've seen you being a jackass in the FI forum. Go somewhere else if you dont have anything positive to add or on topic.
liam
liam
Re: (evosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evosol »</TD></TR><TR><TD CLASS="quote">Does it still fall within the 90 warranty? I had a down2turbo take a dump on me last week. It started smoking really bad one day, i checked the shaft and found that it had become soo loose that the blades came into contact with the comp housing. It lasted me 3 months and no more than 3500 miles. My oil feed and oil drain are sitting pretty, i had taken every precaution while installing my turbo to make sure that it would not be due to an oiling prob. I even ran a ATP oil restrictor and all that bs. Ive heard that some people have had very good luck with MJM turbos, with a few receiving shitty ones.
my only prob is that my turbo is well out of the 90 day warranty. </TD></TR></TABLE>
unfortunately, i bought this a year ago and finally got it in...
i may just go with a precision sc32 or sc50 but now i will have spent over a 1000 to get a turbo running
Re: my down2turbo turbo is fucked!!! (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Fully built motor + eBay turbo = You're an idiot</TD></TR></TABLE>
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: my down2turbo turbo is fucked!!! (turboda6)
couldn't have said it any better..... if you spend so much money at a reputable "shop" then why go with an ebay turbo.[/B]</TD></TR></TABLE>
God DAMN you've got anger issues
no anger issues. jus dont see why he 1. wasted a good turbo with his noobness. and 2. used a ebay turbo on the fully built setup. i woulda used a turbonetics or something with name behind it.
Re: (turboda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboda6 »</TD></TR><TR><TD CLASS="quote">no anger issues. jus dont see why he 1. wasted a good turbo with his noobness. and 2. used a ebay turbo on the fully built setup. i woulda used a turbonetics or something with name behind it.</TD></TR></TABLE>
No, I know where you're coming from - it was just unnecessary, that's all.
Re: (turboda6)
y<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboda6 »</TD></TR><TR><TD CLASS="quote">ill be a jackass all day to these h-t noobs. gives a great kick. by the way, .</TD></TR></TABLE>
i love how you call me an h-t noob but you have less than 50 posts
well i bought it since when i purchased it... everyone on honda-tech was praising his turbos...
so needless to say i believed all you guys
Re: my down2turbo turbo is fucked!!! (igo4bmx)
thats bullshit that you're all giving this dude **** for his turbo going bad. have some heart, ********. lots of people have said good things about down2turbo turbos... its not his fault it went bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">
so needless to say i believed all you guys</TD></TR></TABLE>
Didn't know that, sorry for the shitty luck
Do it right this time
Just look into a T3/T4 .57 trim, .63 A/R or something.
couldn't have said it any better..... if you spend so much money at a reputable "shop" then why go with an ebay turbo. .</TD></TR></TABLE>
He didnt ask for your advice. or your dam pitty. He's just saying his turbo took a dump on him. your posts are meaningless to this thread
Geez man you act like if your the one with the blown turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Didn't know that, sorry for the shitty luck
Just look into a T3/T4 .57 trim, .63 A/R or something. </TD></TR></TABLE>
I think im going with a precision SC50 .48 or .63 a/r (not sure yet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedGreddy »</TD></TR><TR><TD CLASS="quote">He didnt ask for your advice. or your dam pitty. He's just saying his turbo took a dump on him. your posts are meaningless to this thread
Geez man you act like if your the one with the blown turbo</TD></TR></TABLE>
thanks,
FYI everyone, down2turbo sells MJM rebuilt turbos
https://honda-tech.com/zerothread?id=1079225
https://honda-tech.com/zerothread?id=836641
thanks,
oh god, comment on my post count but my post count has nothing to do with my knowledge. obviously yours doesn't either. ive been a member for over almost a year i jus dont bother postin cuz of people like you. find someone u kno that lives near me, i live in sd california and i drive a turbo integra. online threats. im tellin the irs on you.
