is my car detnotating????
Old Dec 14, 2003 | 12:08 AM
ATS*Mark's Avatar
OG triple OG
Default is my car detnotating????
ok , this just randomly started and i dont know how to fix it.....it doesnt happen in first but in second and on...when i hit about 6500 it starts popping and hesitating. i dont know what it is so i was guessing denotation . also my a/f is reading around 10.4 at WOT . is that lean????i tried retarding my cam timing 3 degrees and that didnt help , dont know what to do!!!!!
Old Dec 14, 2003 | 12:19 AM
enginetiks's Avatar
Default Re: is my car detnotating???? (Hella_JDM)
marc... what plugs are you using? Sounds like the flame is getting blown out
Old Dec 14, 2003 | 12:24 AM
ATS*Mark's Avatar
OG triple OG
Default Re: is my car detnotating???? (mschvs)
eg+b16+toda stroker kit= kacey???
and im using brk-7e's ....ill check them tomorow , what should i look for when i take them out?
Old Dec 14, 2003 | 12:53 AM
InTeGrA B18b1's Avatar
gap at .030 or 0.32
Old Dec 14, 2003 | 01:53 AM
safe driver's Avatar
next time that happens check the spark plugs right away. look for silver or white discoloration in the area around the electrode. but since you're running rich, it's probably misfires so you're ok.
Old Dec 14, 2003 | 12:48 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (safe driver)
my plugs are ****** red , like mars sand red , what the **** is that about . i did a compression test 4 days earlier and they were all grey......
Old Dec 14, 2003 | 01:35 PM
enginetiks's Avatar
Default Re: (Hella_JDM)
the red is from octane booster, you might wanna step to cold 8 plugs
Old Dec 14, 2003 | 03:02 PM
fedinteg's Avatar
10.4 airfuel is very rich. the happened to my car the first time i aded race gas.
Change the plugs and gap them to .28
Old Dec 14, 2003 | 04:38 PM
ATS*Mark's Avatar
OG triple OG
Default Re: is my car detnotating???? (fedinteg)
octane booster = hella gay....imma go buy new plugs too
Old Dec 14, 2003 | 04:40 PM
ATS*Mark's Avatar
OG triple OG
kacey i talked to adam today , he said you guys dont have colder plugs for the d series....can you order some for me??? brk-7e's are the ones i need for 2 step colder plugs...and those are the ones that are in my car now!!!
Old Dec 14, 2003 | 04:55 PM
IloveNewt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fedinteg &raquo;</TD></TR><TR><TD CLASS="quote">10.4 airfuel is very rich. the happened to my car the first time i aded race gas.
Change the plugs and gap them to .28 </TD></TR></TABLE>
race gas dont make u run rich
Old Dec 14, 2003 | 06:18 PM
TurboDANDEE's Avatar
Default Re: is my car detnotating???? (MordecaiPSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MordecaiPSI &raquo;</TD></TR><TR><TD CLASS="quote">
race gas dont make u run rich</TD></TR></TABLE>
it did with my car
it was street tuned for 11.5:1 a/f and i added race gas, the car run rich, around 10'ish a/f.
Old Dec 14, 2003 | 06:59 PM
LiLOtaku's Avatar
I'm having the same problem at the moment.
The car was running fine, and then outta the blue it started stumbling whenever i hit full boost or got near full boost. The RPM's wron't rise at all, and the car just starts jerking back and forth when on the gas.
It does this off and on, sometimes the car runs fine and other times it doesn't .
I have my plugs gapped at .030. They didn't show any signs of leaning or detonation, but they did show up a little black.....rich.
Anyone else have this problem?
Old Dec 14, 2003 | 07:08 PM
boostn420's Avatar
Default Re: is my car detnotating???? (LiLOtaku)
What do you guys have as far as ignition system. It seems a problem with spark. Cylinder pressures are a lot higher under full boost and with all that fuel its hard for a stock system to keep up. Especially if you run rich with race gas, what about an incompelte burn, thats rich right. Maybe the stock ignition system is being over worked. Try upgrading it.
Old Dec 14, 2003 | 07:14 PM
LiLOtaku's Avatar
Default Re: is my car detnotating???? (boostn420)
I'm running stock ignition at the moment.
But the thing is, the car was running fine for more than a week, and then it just started doing its odd thing. The other odd thing is, it doesn't do it all the time.
I'm thinking about gapping the plugs to around .028 or .026 and I'll see what that does......
Old Dec 15, 2003 | 07:33 AM
LiLOtaku's Avatar
bump
Old Dec 15, 2003 | 07:41 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
You're supposed to retard your ignition timing, return your cam timing to stock. That has nothing to do with detonation, it's ignition timing. Get a timing light and a Helms or Haynes manual and back up your timing at the distributor 2 degrees from stock.
I don't know why you're running octane booster. Just run 91 octane for less than 9-10 psi. Get some BKR6E's or 7E's, gapped at .030", no more no less.
Are you running the blue box? if so, check your fuel pressure @ idle with the vac. hose off. If it's more than 42 psi, lower it to about 39-40 or so @ idle. check your fuel filter, replace if needed. Run some injector cleaner or fuel system cleaner in the tank to clean things out. There's a lot of things that could be going on.
Old Dec 15, 2003 | 07:46 AM
swlabhot's Avatar
Default Re: is my car detnotating???? (boostincoupe)
Get yourself a new set of plugs, gap them correctly and change them!!! Problem solved!
Old Dec 15, 2003 | 03:33 PM
ATS*Mark's Avatar
OG triple OG
Default Re: is my car detnotating???? (swlabhot)
i got bkr-7e's gapped them to .028 , problem solved
Old Dec 15, 2003 | 10:38 PM
enginetiks's Avatar
I told you.......how youlike that ferrari on the dyno?
Old Dec 15, 2003 | 10:56 PM
ATS*Mark's Avatar
OG triple OG
i nut my pants hella times man , the lotus was tight too , whens he gonna bring the enzo in?
Old Dec 15, 2003 | 10:59 PM
ATS*Mark's Avatar
OG triple OG
ya dood my plugs were fucked royaly....they all good now . i just need a boost controller and some other goodies and ill be stoppin by the dyno.
i was having cooling system problems too , ive learned my lesson to never go to autozone for thermostats , they sold me 2 bad ones , and the third would stick randomly....honda thermostat+honda coolant+coolant flush= perfect cooling system
SGVridgerunner
Nov 8, 2007 01:28 PM
sickerhatch
Feb 18, 2005 05:37 AM
singlecammajamma
Jun 26, 2004 11:30 AM
Tuney
Aug 13, 2003 01:42 PM
nicksweetlude
Feb 25, 2002 06:05 PM
