To much boost
Old Nov 5, 2007 | 05:23 PM
1991hb's Avatar
Default To much boost
Alright, my brother has a '88 crx with a b18a1 in it. He recently put a turbo on it and and it has 16 pounds of boost. He wants to know how he can get that down to normal like between 6-8 pounds of boost. I don't know anything about turbo's so I can't help him. I'm not exactly sure what kind of turbo it is. If it was tuned correctly wouldn't that help a lot? Thanks in advance.
Old Nov 9, 2007 | 09:17 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: To much boost (1991hb)
What turbo is he running? Internal or external wast gate (W/G). He either need to adjust the W/G rod if internally gated or change the W/G spring to something smaller if externally gated.
Old Nov 9, 2007 | 10:35 AM
HAMOTORSPORTS's Avatar
Default Re: To much boost (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">What turbo is he running? Internal or external wast gate (W/G). He either need to adjust the W/G rod if internally gated or change the W/G spring to something smaller if externally gated.</TD></TR></TABLE>
AND get a cheap manual boost controller
edit: Corrected
Modified by HAMOTORSPORTSUSA at 3:48 PM 11/9/2007
Old Nov 9, 2007 | 02:42 PM
JaredKaragen's Avatar
everyone who has the slightest bit of knowledge knows that you can NOT go lower than your WG's PSI spring.
END OF LINE.
fro
Mar 11, 2005 11:53 PM
civic909
Sep 22, 2004 12:15 PM
brasilstreet
Jun 16, 2004 02:21 PM
ek9vboi
Nov 22, 2003 07:47 AM
IZsd
May 6, 2003 12:17 PM
