Lowering boost on an internal wastgate?
Old May 5, 2003 | 12:54 PM
IZsd's Avatar
Default Lowering boost on an internal wastgate?
Maybe a stupid question but on a td05 how can I lower the boost??? Im looking to run in the 5-8 range. Any help would be really great.
Later IZ
Old May 6, 2003 | 10:47 AM
IZsd's Avatar
Anyone?
Old May 6, 2003 | 11:01 AM
Sonny's Avatar
Default Re: Lowering boost on an internal wastgate? (IZsd)
You can shorten the actuator arm which will cause the turbo to spool slower and possibly reduce your max boost.
Sonny
Old May 6, 2003 | 12:17 PM
crxY-49's Avatar
Default Re: Lowering boost on an internal wastgate? (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">You can shorten the actuator arm which will cause the turbo to spool slower and possibly reduce your max boost.
Sonny</TD></TR></TABLE>
you would actually lengthen the actuator arm...but this causes more lag.
you can also use the carb spring method which i heard is pretty good...thats what im going to be using. check out homemadeturbo.com. there is a lot of info about this topic there.
Horseofcourse
Jul 27, 2007 10:39 AM
r1lorenzini
Feb 19, 2004 11:54 AM
onePOINTsix
Aug 19, 2003 10:59 AM
92-h23a1
Aug 7, 2003 08:40 AM
Integra187
Sep 21, 2001 07:13 PM
