Zex install with MSD Dig 6 and MSD window switch
Old May 6, 2009 | 04:51 PM
TheRappist's Avatar
Default Zex install with MSD Dig 6 and MSD window switch
Hey, I am about to install my ZEX wet kit with a MSD dig 6 and msd window switch. Just trying to get confirmation on how to hook it up.
Would I install the switch in the car, to power the whole system, but then, run the nitrous solenoid and msd dig 6 to get 'power' from the msd window switch, which in turns, gets power from the battey?
Old May 6, 2009 | 05:10 PM
RC000E's Avatar
Default Re: Zex install with MSD Dig 6 and MSD window switch
Wiring advice via Honda-Tech...NOT a good idea.
Window switches, as I recall, supply a ground signal. The simplest way is to wire the Zex using the master arming switch as instructed, and use the ground supply from the window switch to activate the relay for the ZEX system thus making they system operate when the throttle conditions are met.
The MSD dig 6 should be wired as instructed, and have the pink wire supplied with 12 volt along with when the master arming switch is activated.
Old May 8, 2009 | 07:56 PM
TheRappist's Avatar
Ok, cool Thanks! I am gonna try that.
BoredNStroked
Mar 12, 2006 09:36 PM
ubnpast
May 17, 2004 06:05 PM
zcivic91
Jan 15, 2003 12:03 AM
RedDawg
Apr 1, 2002 04:31 PM
LshatchTurbo
Feb 19, 2002 08:58 PM
