MSD Pro Billet Distributor
Old Apr 7, 2006 | 08:13 AM
  #26
tony1's Avatar
Default Re: (VE junkie)
Yes, it will.
Old Apr 7, 2006 | 08:33 AM
  #27
tepid1's Avatar
Default Re: (tony1)
M&W Pro 10 right?
Old Apr 7, 2006 | 08:51 AM
  #28
tepid1's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">To my understanding, all hall effect sensors output a square wave output, and the honda computer can't read that right. </TD></TR></TABLE>
Isn't the RPM signal a square wave signal?
Old Apr 7, 2006 | 08:55 AM
  #29
tony1's Avatar
Default Re: (tepid1)
Yes, the tach signal is a square wave signal, but it's not the signal in question.
Old Apr 7, 2006 | 08:58 AM
  #30
tepid1's Avatar
Default Re: (tony1)
but the ecu can read the square wave..... that is all I am trying to say. So we can modify the ECU to read it like the RPM does.....
I will look more into this when I get out of work.
Old Apr 7, 2006 | 09:01 AM
  #31
tony1's Avatar
It's a completely different circuit, won't work. The square wave stuff is on the output side of the ecu, not the input side.
Old Apr 7, 2006 | 09:19 AM
  #32
jsprelude's Avatar
Default Re: (tony1)
It sucks because you will never see them make one for the H series!
Old Apr 7, 2006 | 09:22 AM
  #33
Turbo-charged's Avatar
Default Re: (jsprelude)
haha jay....nobody makes anything for the H...lets put a B series in your car!
btw what do you want to do with my distributor thats on your car? buy it or give it back? haha. you should buy it so that i can affored injectors hahhaha
Old Apr 7, 2006 | 09:25 AM
  #34
jsprelude's Avatar
Default Re: (Turbo-charged)
I have it sitting in my garage ill run it back up to the shop next week! Thanks
Old Apr 7, 2006 | 09:30 AM
  #35
cool...did you just get another factory one?
Old Apr 7, 2006 | 09:40 AM
  #36
Turbocivic94's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I have no idea, but i find it hard to belive that an msd ignitor would be any more reliable than an oem ignitor. lol Your best bet is to run an M&W and remove the ignitor all together. </TD></TR></TABLE>
I already sold the digital 6 and I will be buying M&W
wanna trade HVC coil for the one that works with M&W
Old Apr 7, 2006 | 09:45 AM
  #37
tony1's Avatar
Default Re: (Turbocivic94)
You can use the HVC coil with the M&W.
Old Apr 7, 2006 | 09:53 AM
  #38
underpressure02's Avatar
Default Re: (tony1)
anyone got a link to the M&W?
Old Apr 7, 2006 | 10:01 AM
  #39
tepid1's Avatar
Default Re: (underpressure02)
http://www.mwignitions.com
Old Apr 7, 2006 | 10:04 AM
  #40
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsprelude &raquo;</TD></TR><TR><TD CLASS="quote">It sucks because you will never see them make one for the H series! </TD></TR></TABLE>
It doesn't matter anyway.. for (a litte less than) $200 more you can get an M&W ignition setup, eliminate the ignitor and run the "recommended Crane PS92 Coil". Keep the oem reliability and eliminate the OEM unreliability at the same time.
got caught up in the hype of this thread, but remembered some notes I had regaurding the M&W.
Old Apr 7, 2006 | 10:39 AM
  #41
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You can use the HVC coil with the M&W. </TD></TR></TABLE>
Wouldn't it be better to run the Crane coil versus HVC or its the same?
Old Apr 7, 2006 | 10:53 AM
  #42
*Boostwerks*'s Avatar
I wish this thread could have stayed "tech" about the MSD distro.
Old Apr 7, 2006 | 10:54 AM
  #43
JDogg's Avatar
i have done a couple of cars w/the msd dizzy...
it seems to work really well. the cam/crank signals are MUCH more stable than hte signals from the factory dizzy. From my understanding they use a hall effect pickup with some sort of circuitry to convert it into something the stock ecu can understand. w/the aem and the msd dizzy i can idle cars rock solid at 5-600rpms if i want. Thats impossible w/a mag pickup b/c the voltage output isnt strong enough, the only other thing i have been able to do that with is the cam gear/hall effect setup.
longevity is my only consern
Old Apr 7, 2006 | 11:43 AM
  #44
tepid1's Avatar
Default Re: (JDogg)
Is the signal still strong in the 9k RPM + range?
I know in the OEM distributors the signal is a little sketchy at times. Especially using AEM EMS....
I still have not gotten an answer about being water tight.... Is this thing going to be prone to getting wet inside?
Old Apr 7, 2006 | 12:46 PM
  #45
tepid1's Avatar
I did a little research....
If you all are tired of frying your OEM ignitors then just build this little circuit. I found this on pgmfi.org
Old Apr 7, 2006 | 12:50 PM
  #46
seen4ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">
Tony, Can we run MSD ignitor with oem distirbutor?</TD></TR></TABLE>
you can't, i asked this last year and MSD told me it wouldn't work due to the way the signal is converted.
so basicly i need to get my trustly voltometer and put the leads on the - & + from the output wire from the ignitor???
Old Apr 7, 2006 | 12:54 PM
  #47
seen4ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">I did a little research....
this was also integrated into the J&S ultrasafeguard as well, so in case you had one of the newer models (after 2004) then you can just wire it inline the ecu to a ignition box (MSD, M&W, autronic, take your pick) and boom ready to go.
i know someone locally just about a autronic R500 or soemthing, i **** myself to even think about dropping 1000 bucks on a ignition box, i guess that's what you need for his COP setup, but pretty nuts.
Old Apr 7, 2006 | 12:57 PM
  #48
tony1's Avatar
Default Re: (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">
so basicly i need to get my trustly voltometer and put the leads on the - & + from the output wire from the ignitor???</TD></TR></TABLE>
Not the ignitor, forget about the ignitor right now. That's on the output side. I'm talking about the "hall sensors" they use, which feed the engine position signals to the ecu. The 3 sensors that are inside the distributor, one has 1 tooth, one has 4, and one has 24 (obd1).
Old Apr 7, 2006 | 01:05 PM
  #49
seen4ever's Avatar
Default Re: (tony1)
wouldn't the output of the hall sensor be the issue? as it triggers the ignitor? so input to ignitor would be output of hall sensor? hence the xtra plug with 5 wires or whatever that run to new ignitor circuit.
or am i just dumb since i live near wade?
Old Apr 7, 2006 | 01:07 PM
  #50
seen4ever's Avatar
****, now i get it, hall sensor outputs to ecu via the CPS wire correct? so i can just run the + from multimeter to that wire and then ground it to see wtf it does? but i'd have to think even if it was hall sensor, the conversion would be done inside the distributor, as the stock ecu can't accept that feed.
which is my guess at wtf you are getting to. so only real solution is....taking apart the dizzy?
