motor sputtering when v-tec comes on
Old Jul 18, 2003 | 12:03 PM
shotty's Avatar
Default motor sputtering when v-tec comes on
I have a b-16 which used to be turbo'ed by a greddy 15g. I switched and went with a garrett t3/to4e as well as upgraded quite a few other things. It ran fine before, but with the new setup once vtec comes on it will sputter and go lean. So I obviously let off right away. I currently have vtec set at 6000rpm on my zdyne gold secu. I am going to bring it down to about 5400rpm once I get the laptop back and maybe bring up the boost fuel %. Any help as to why it is doing this would be appreciated.
Old Jul 19, 2003 | 10:19 AM
incognitoracerr's Avatar
Default Re: motor sputtering when v-tec comes on (shotty)
I was having the same exact problem so I went with a holley 67gph electrical fuel pump and I am running some 345cc injectors and now i never lean when vtec kicks in...(fuel pump is probably more than likely the problem if you have not done it....)
Old Jul 19, 2003 | 10:46 AM
RenoRacing's Avatar
Default Re: motor sputtering when v-tec comes on (incognitoracerr)
fuel is definately your problem, i had a very similar issue w/ my b16 turbo, it'd be alright till top end when it just started to build boost and vtec. They were both fighting for the fuel and it just wasn't enough, i ended up turning up the 12:1 fmu all the way and the b&m all the way and it ran great, that was stock injectors on 6psi.
Old Jul 19, 2003 | 11:53 AM
nsxmatt's Avatar
Default Re: motor sputtering when v-tec comes on (HavokRacing)
Sometimes low oil level can cause vtec to cut out but not sure about the lean condition.
Old Jul 19, 2003 | 02:22 PM
shotty's Avatar
ok. Well I seemed to have pointed it out a little more. It isnt when vtec comes on, its only at WOT. I currently have the .35bar spring in my tial WG and the pressure of the exhaust itself is pushing the WG open. I am running the AVC-r so I just thought I would be able to set my boost anyway. I dont understand the lean condition though. I have 450cc injectors, Zdyne gold secu, Walbro 255 in-tank pump. I am gonna see what happens with a stiffer spring first and if it will still run like crap during WOT.
Old Jul 19, 2003 | 04:23 PM
b16ahybrid's Avatar
How do you know that your runing lean? Is that just a guess or do you know for a fact?
Is it a sputter (bogg) or hessitation, or does it just feel as though power drops off once you hit wot?
Old Jul 19, 2003 | 05:26 PM
shotty's Avatar
Default Re: motor sputtering when v-tec comes on (b16ahybrid)
b16ahybrid]How do you know that your runing lean? Is that just a guess or do you know for a fact?
From my A/F ratio meter
It will spit and sputter and wont rev anymore. It will go fine with the pedal down only about an inch but anything past that it spits/sputters/bogs.....basically will not go, will not rev any higher.
Old Jul 22, 2003 | 08:44 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty &raquo;</TD></TR><TR><TD CLASS="quote">b16ahybrid]?
From my A/F ratio meter</TD></TR></TABLE>
Is it just a autometer (or like) thats hooked up to your stock o2 sensor or is it a wide band?
If it's just hooked up to your stock o2 then don't use that to determin anything. I have one and it tells me that i'm lean under boost sometimes (eventhough my air/fuel ratio is rite at 12:1) they cannot accuratly read any air/fuel ratio's that are not close to stoich.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty &raquo;</TD></TR><TR><TD CLASS="quote">It will spit and sputter and wont rev anymore. It will go fine with the pedal down only about an inch but anything past that it spits/sputters/bogs.....basically will not go, will not rev any higher.</TD></TR></TABLE>
It sounds as though it's actually runing too rich. Your best bet is to get it on a dyno that has a wide band o2 so you can accuratly check your air/fuel ratio.
ensracer
Sep 15, 2005 10:15 PM
dylokjai
Oct 4, 2004 01:50 PM
turbob16
Apr 1, 2003 06:51 PM
ludelvr
Mar 31, 2003 11:22 AM
