Motor mount inserts questions
well im finally gonna get em , my wheel hop is too bad and ill start with the cheapest part.
anyway , would the susp techniques do the job good? any toher suggestions ?
i remember we had a set for our gen 2 teg and one of them ended up not getting used cuz it didnt fit right, i dont know if it was the wrong one of what , anyone else have fitment problems .?
also the susp tech ones are 37.95 for the set of 3, any one got better prices than summit on these?
the stock mounts are supposed to limit the amout of vibration to the passenger compartment, of course stiffening them will transfer more noise and vibration, learn to live with it if you want better handling.
will it help with wheel hop?
thats all im concerned with .i rather deal with a bit of vibration than a broken tranny or soemthing from such violent hop .
it is designed to reduce wheel hop, if it doesnt then you have to look at spring dampener settings, as they are allowing the tire to rebound when it should be planted, get the inserts, play with settings (koni yellows etc..) and tire pressure, even on a radial play with 12 - 20PSI see how it goes, their is a lot more involved then the insetrs, if you need to go further there is the radius rods from Z10 eng., or comp. eng, or chassiss eng.
i pretty much garuntee i will need more than them off the bat . but i want to go with the cheapest things 1st to reduce it until i have the money for the big stuff. anything will help me right now.
Vibration with the mount inserts isn't all that bad.
In fact, I don't even notice it anymore.
I'm only running the front two though, cos the rear one is a bitch to get to.
Well my car idle hard, as in the steerwheel would shake(You'll get used to it). I also bought the first gen inserts that didn't have the zip tie things with it and they vibrated themselves out(one into the A/C pulley). I had to goto Home Depot to get monster zips to keep them in place. I'd say they were okay, but didn't solve my wheel hop, I'd say a good set of springs and shocks would cure the problem better. Then step up the the radius bars. I know not much of a budget saving, but that will cure your problem(s). Later Allen
well im hoping they do something , they werent ver expensive, but im hoping they at least help a bit .i cant get this thing to launch at all without hopping the tires. even on street tires, they hopp like hell between hard shifts.
damnit . . . . . i need a sponsor . this is getting expensive. i was planning on not even touching the car this year .i already just ordered the mount inserts, blow down tube. saftey blow off valve, msd cap, msd plug wires, msd dig 6, msd blaster ss, upgraded to single fogger wet kit , and a **** load worth of jets, new lines, goodwridge fittings, gutted it , ripped out the whole ac system and not even on the dyno yet to get tuned . .i either need a sponsor or a better job.
redDAinteg
Jun 1, 2006 08:33 PM
