430bhp @ 22psi
Old Apr 19, 2002 | 10:20 AM
austrian type-R's Avatar
Default 430bhp @ 22psi
Today it was my final dyno session. We made a couple of runs and dialed in the cam gear setting + fine tuning the ignition table with the Haltech e6k. The following Plot shows the max numbers of todays dyno runs. The outside temperature was about 20 degres C and the elevation is about 700 meters. This run was with 22psi. It shows 430bhp (374whp). MY tuner said it is not good for boosting always that heavy and the engine will not hold more than 20000 miles with that amount of boost. He looked into the plug holes with some special scope and noticed some detonation signs on the pistons. The sleeves are still fine. He told me to run about 1 Bar daily and I´ll be fine. Maybe boosting 1.3 Bar when it is cold outside for short periods. A dynorun with 1 Bar was showing 350bhp (310whp).
The tourqe is 425 Newtonmeter on the dynoplot below (it is 313 lbs torque)
MY engine has a cr of exact 9.1:1.
[Modified by austrian type-R, 8:22 PM 4/19/2002]
Old Apr 19, 2002 | 10:25 AM
b18bturbo's Avatar
Default Re: 430bhp @ 22psi (austrian type-R)
not bad.. really nice...
Old Apr 19, 2002 | 10:26 AM
DSF's Avatar
DSF
Geez, my eye's must be really messed up. It looked like the plot was in another language or something
Those are great numbers, especially torque Man, you got *****! I don't know if I could boost that high that soon after blowing my motor. Are you running the standard DRAG3 turbo?
Old Apr 19, 2002 | 10:29 AM
Default Re: 430bhp @ 22psi (DSF)
Turbo, intercooler, pipings, downpipe, manifold is the from DRAG III kit.
Old Apr 19, 2002 | 10:32 AM
Pritos's Avatar
New User
jeebus. u r my hero.
I'm gonna shoot for 16-18psi daily on my sohc. I'm hoping to get good results like u've been getting.
Old Apr 19, 2002 | 10:55 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 430bhp @ 22psi (Pritos)
Way to go christian.
art
Old Apr 19, 2002 | 11:00 AM
kpxgq's Avatar
Default Re: 430bhp @ 22psi (Arturbo)
that curve is beautiful
Old Apr 19, 2002 | 11:14 AM
Adi Radoncic's Avatar
On Fire!
Good Job! I'm glad everything worked out great for you. I'm really empressed by your horsepower numbers!!!
Adi
Old Apr 19, 2002 | 11:34 AM
dazz's Avatar
Good numbers!
Whats the air/fuel like?
Old Apr 19, 2002 | 01:24 PM
Default Re: 430bhp @ 22psi (dazz)
Lamda ratio is 0.92 - 0.95. That is about 13 - 13.5:1 or so.
Lamda 1 is 14.5:1
Old Apr 19, 2002 | 01:29 PM
Teg4e's Avatar
Default Dip?
As said before very nice numbers; your ***** are bigger than mine will ever be.
That said, what happened in the 2000's.....there's a little hesitation before picking back up.
Old Apr 19, 2002 | 10:24 PM
RH+G's Avatar
What size turbo was this again?
Old Apr 20, 2002 | 12:18 AM
Default Re: 430bhp @ 22psi (RH+G)
T3/T04e
My tuner thinks this *hesitation* comes from the long intake way, the air flow is too low or something. Usualy typical turbo cars which comes stock from the factory so not have so large throttle bodys and so large intake runners. So this is maybe from that things.
I think when I would remove the long way thru the IC, this hesitation is away.
Old Apr 20, 2002 | 01:10 AM
Cyber ITR's Avatar
does bigger turbo gives higher torque ????
cuz i got 520nm @ 6psi with t28
Old Apr 20, 2002 | 01:25 AM
Default Re: 430bhp @ 22psi (VTEC_SiR)
What are you talking about?!?!?! 510nm @6spi NOOOOO way!!!!!!!!!!! You mean 210, right?
A t28 is smaller than a T3/T04e and yes, bigger turbos making more tourqe and hp. I bet with GSR cams I can make even more tourqe, cause they are not so aggressive.
Old Apr 20, 2002 | 02:15 AM
Cyber ITR's Avatar
well believe it or not
Old Apr 20, 2002 | 02:27 AM
That would be about 393 lbs tourqe.
Okay I don´t want to be a hater, but there is something wrong with that dynoplot. On this planet there is NO car with 1.6 litre? displacement making only 6 pounds of boost and hitting such high torque numbers. Some other tech should confirm this too, please.
Old Apr 20, 2002 | 02:33 AM
Cyber ITR's Avatar
errr i got B18C JDM darlin .............
[Modified by VTEC_SiR, 11:34 AM 4/20/2002]
Old Apr 20, 2002 | 02:41 AM
Well my friend, that is even not possible with a 3 litre engine and 6 psi.
Old Apr 20, 2002 | 02:43 AM
Cyber ITR's Avatar
uhhhhh i dunno then , i might go again next month dyno my car again
Old Apr 20, 2002 | 02:49 AM
I would go to an other place to get a better compare. Are those bhp a brutto nm or wheel hp and wheel nm? When those numbers are to the engine, then the hp seems also fake to me. Hence, the B18C has stock 140KW and you are making only 7.92 more than that.
The stock nm of the B18C is about 178, what I can remember. Do you realy think with that low boost you can add another 350 newtons.
Old Apr 20, 2002 | 02:55 AM
Cyber ITR's Avatar
errr all figures are @ wheels
the dyno is rolling dyno.
eh dun worry ur car always be faster neway
Old Apr 20, 2002 | 03:10 AM
We are here to help each other, this is not my car is faster than yours board.
Okay, that means you have about 240 hp to the engine, don´t know your exact drivetrain loss. These numbers are a bit low for turbo @ 6psi, but they are okay and realistic. NOT that torque.
Old Apr 20, 2002 | 09:14 AM
gsrt's Avatar
did you change any internal?
Old Apr 21, 2002 | 12:13 PM
Default Re: 430bhp @ 22psi (gsrt)
SETUP:
DRAG III turbo kit
Turbo is water cooled
Haltech e6k ECU
Eagle rods
JE pro series pistons 9:1
Crower valve springs & retainers
AEM fpr
Skunk2 cam gears
Walbro fuel pump (from JRSC kit)
RC 440cc injectors
Clutchnet stage 2
Fidanza flywheel (goes out, to light IMO)
3" Thermal RD exhaust
3" Carsound cat
3" midpipe resonator
17row oil cooler
JR thermostat
5 Greddy gauges
Apexi AVC-R
Tial wastegate 35mm
