most powerful d16z6
Old Oct 16, 2002 | 05:46 PM
oldirt3277's Avatar
New User
Default most powerful d16z6
Plans on port and polishing a d16z6, need some help on internals for 12 lbs. of boost and a 100 shot of laughing gas. Any help appreciated.
Old Oct 16, 2002 | 07:10 PM
biassj's Avatar
Default Re: most powerful d16z6 (oldirt3277)
Turbopanda has a hybrid piston/rod package going, check it out.
https://honda-tech.com/zerothread?id=267641
Old Oct 16, 2002 | 07:22 PM
MikeMAN's Avatar
Default Re: most powerful d16z6 (biassj)
i would definately ****** up that deal from turbopanda...
can't be beat..really!
Old Oct 23, 2002 | 12:35 PM
turbo95coupe's Avatar
Default Re: most powerful d16z6 (MikeMAN)
i was under the impression that the bore on a d16z6 was 84mm not 75mm or atleast thats what the local tuner shop told me.
Old Oct 23, 2002 | 12:44 PM
GasHuffer's Avatar
Default Re: most powerful d16z6 (turbo95coupe)
84mm is a B20 crv motor
Old Oct 23, 2002 | 12:46 PM
EP3_05's Avatar
Don't listen to that shop....hahaha
Old Oct 23, 2002 | 02:22 PM
KoRE's Avatar
that is a great package but for what he's doing he should get some stronger pistons and stronger rods then supra pistons and b16 rods....
you should also look into sleeving your block
ion_four's Avatar
if you're on a limited budget; screw the port and polish, anything great will cost alot and will be completely eclipsed by a few extra pounds of boost that could be had by getting some killer rods and pistons. Instead of getting the stock b16 rods (ala. turbopanda) you could get some performance rods as they might be beefier than the performance version of d16 rods. There's also the fact that turbopanda's stuff is used, which is a little sketch (nothing to do with him, personally) to me, since you're trying to push them.
Old Oct 23, 2002 | 03:30 PM
W.Zero's Avatar
Default Re: most powerful d16z6 (ion_four)
i built my sohc back in the day and it was turbo/nos but if thats what you want to do your gonna have to sleeve your block and get after market rods and piston. if you are going with that setup then do it all. if you just do the bottom end then youll have problems with the head. trust thats what i did and my valves melted so i had to pay twice the money on labor. if you do the bottom the head will already be off so do both the same time.
Old Oct 23, 2002 | 04:03 PM
Loco Honkey's Avatar
Default Re: most powerful d16z6 (KoRE)
Well, since you have the answers, how about you come up with a rod/ piston/ ring package that'll handle 22 PSI for under $500 shipped.
What?
That's right... I didn't think so...
Old Oct 23, 2002 | 04:06 PM
W.Zero's Avatar
the only problem with this package is its not going to beabl to handle boost and a 100 nos
Old Oct 23, 2002 | 04:15 PM
ExospeedAMcrx's Avatar
Default Re: most powerful d16z6 (W.ZeroB18C1T)
i say, forget the NOS idea. youre bringing in two diff things the engine has to deal with in the fuel management dept. its already complicated enough to tune a properly fueled high boost turbo system and when you add NOS, there is more fuel tuning you have to do.
How about concentrating on building an All turbo setup. You dont need NOS when you can just turn up the boost, and its much easier to deal with.
Old Oct 23, 2002 | 04:23 PM
98civicEX's Avatar
Default Re: most powerful d16z6 (House of Boost)
What?
and this brings up the entire high compression vs low compression discussion again. turbopanda's set-up will give you like 8.2:1 or something around that....why not keep stock internals and boost 12psi all day long...i know there are PLENTY of people who boosted their d16's on stock internals......i ran on 12psi on stock internals for a few months..not one problem if money is a issue boost on stock internals...
[Modified by 98civicEX, 5:26 PM 10/23/2002]
Old Oct 23, 2002 | 04:25 PM
mntdewred's Avatar
Default Re: most powerful d16z6 (98civicEX)
because i want to boost higher than a measily 12psi...
Old Oct 23, 2002 | 06:19 PM
POLLO's Avatar
Default Re: most powerful d16z6 (mntdewred)
I bought that hybrid piston and rod combo and with the hondata and a great nice guy who can tune hondata for me, hell 12 psi are gonna be daily driven boost.....
Im shooting for 22psi with hondata and other secret stuff...
** EDIT **
No nitrous either, that's just another variable open to possible damage.
[Modified by POLLO, 10:21 PM 10/23/2002]
Old Oct 23, 2002 | 06:21 PM
Mase's Avatar
Default Re: most powerful d16z6 (POLLO)
alberto, what about your SI? u gonna leave it stock?
Old Oct 23, 2002 | 06:23 PM
WONG FRIED RICE's Avatar
i recommend u get some stronger rods, and low compression pistons, w/ total seal piston rings. Have the rods shot peened. I have stock rods and pistons on my D16Y7/8, and i run 10psi all day long. (ported head w/ 5 angle valve job, thicker head gasket) My piston rings are starting to go tho, because i get an awful burning oil smell when i boost. So...HIGHLY recommend those pistons/rods.
Old Oct 23, 2002 | 06:29 PM
POLLO's Avatar
Default Re: most powerful d16z6 (Mase)
Maseta,
Yes, the Si stays stock, that will be the daily driver, that was modified before, I'll leave it alone for nice long trips.
Nour Nassar
Jan 17, 2016 08:37 PM
DelSolDon
Apr 2, 2011 11:29 AM
civproject14
Jun 28, 2005 11:19 AM
GapxGuy
May 18, 2005 08:40 PM
Tyreece04
Aug 16, 2004 04:03 PM
