HS Turbo Cams
Old Oct 11, 2002 | 02:44 PM
Rocket's Avatar
Default HS Turbo Cams
Update
I should have the turbo B-series Vtec cams ready for testing in about 2 weeks. Specs are secret right now but will be released when I finalized the configuration of the cams.
Old Oct 11, 2002 | 02:50 PM
rjardy's Avatar
Default Re: HS Turbo Cams (Rocket)
sounds good!
Rob
Old Oct 12, 2002 | 09:02 AM
slowcivic's Avatar
New User
rocket, will the Turbo cams be compatable with a Stock GSR Valvetrain?
Old Oct 12, 2002 | 09:18 AM
SoulSurfer's Avatar
Default Re: HS Turbo Cams (rjardy)
sounds good!
Rob
He said VTEC...not LS...
Old Oct 12, 2002 | 09:41 AM
salt's Avatar
will these cams make power over 9000 rpm ?
steve
Old Oct 12, 2002 | 09:43 AM
done's Avatar
ill be glad to test them
Old Oct 12, 2002 | 10:30 AM
Jared's Avatar
Default Re: HS Turbo Cams (Jordo)
great, i'm interested. what kind of prices are we looking at?
Old Oct 12, 2002 | 10:47 AM
Pelican's Avatar
Default Re: HS Turbo Cams (Jared)
Oh ****. Might have to jump on this. *Holds breath for testing*
Bump the dialed-out GSR's
Old Oct 12, 2002 | 05:12 PM
AB16A2T's Avatar
Default Re: HS Turbo Cams (Pelican)
OOOooo Will there be B18B Turbo Cams? I wanna get a good set of turbo cams for my non-vtec self. LoL
Old Oct 13, 2002 | 05:54 PM
Jared's Avatar
Default Re: HS Turbo Cams (AresB18BTurbo)
Damn, I'm fiending for these things. what kind of tuning will the reuquire? or are they made to be changed very little from 0,0?
Old Oct 14, 2002 | 04:48 AM
BLKCRX's Avatar
i want a set !! do we know how much there going to cost... so i can start saving NOW !!
Regards James
Old Oct 14, 2002 | 06:55 AM
VTC_CiViC's Avatar
Default Re: HS Turbo Cams (BLKCRX)
Any plans for SOHC VTEC Turbo cams?
Old Oct 14, 2002 | 10:04 AM
slowcivic's Avatar
New User
Top!
Old Oct 14, 2002 | 10:22 AM
mntdewred's Avatar
Default Re: HS Turbo Cams (VTC_boost-less_CiViC)
yes
Old Oct 15, 2002 | 12:02 AM
BLKCRX's Avatar
Default Re: HS Turbo Cams (mntdewred)
top also..bc i want these cams !! asap !@ hehhehe
Regrards James
Old Oct 16, 2002 | 07:56 PM
98civicEX's Avatar
ttt, also intrested and waiting for the springs for these as well.
Old Oct 20, 2002 | 02:31 PM
Rocket's Avatar
Default Re: HS Turbo Cams (98civicEX)
Cams will probably be tested with the JG Manifold to see how the combo works together.
Old Oct 20, 2002 | 02:34 PM
BLKCRX's Avatar
JG mainfold.... rocket cams.... built engine... 30psi.. hummm !!! i wonder !!
Regards James
Old Oct 20, 2002 | 02:41 PM
Rocket's Avatar
Cams will be availabe on CNC steel blanks soon.
5 gram HondaSaver Ti retainers are also now available. I guarantee them against wear.
Old Oct 20, 2002 | 06:07 PM
Jared's Avatar
Will the HS turbo cams work with ITR valvetrain and crower tit retainers?
Old Oct 20, 2002 | 06:57 PM
Midwestrider's Avatar
Will it just be tested on a vtec motor or both a vtec and non-vtec motor?
Old Oct 22, 2002 | 11:53 PM
Rocket's Avatar
Default Re: HS Turbo Cams (Midwestrider)
Only on the VTEC engine at the moment.
Old Oct 23, 2002 | 02:33 AM
Thank you Rocket..
Old Oct 23, 2002 | 02:56 AM
DSF's Avatar
DSF
Rocket ownz my wallet
Old Oct 23, 2002 | 01:17 PM
98civicEX's Avatar
Default Re: HS Turbo Cams (DSF)
anything for us SOHC guys yet?
