Most powerful B16 stock bore and stroke size???
Im just wondering what the highest #'s are from a 81mm B16a??? im building a drag crx, using stock bore size, and was curious if im trying for unobtainable numbers?
Re: Most powerful B16 stock bore and stroke size??? (Garage 808 Hatch)
I've made 570whp on my stock sleeve'd stock stroke b16a. Car went 10.4@142.7mph in sfwd trim. I dont think anyone has really pushed the limits of the b16 yet and I'd like to see it done. A lot of power +rpm without alot of torque is definitly a good thing for a fwd trying to get down the track.
Re: Most powerful B16 stock bore and stroke size??? (Boner_Ben)
ya, thats our thinking. im shooting for 550whp on boost, then spraying in 3rd and 4th, probably a 125-175 shot. its a GE HD sleeved, b16, manley turbo tuff rods, arias 9:1 pistons, with upgraded wrist pins, ported head, gsr cams, t3/62-1 turbo, .82 ex, pwr 6x10 air to water IC, 3" piping, zex direct port kit, hondata s300, Precision 1000cc's, aeromotive a-1000 pump, 1 gal cell, -10 feed, to two -6 lines, 1 going into each end of the fuel rail, 68mm TB, ported mani runners on a victor-x, 4" dp and 4" alum exhaust.
my goals are between 650-700whp??? think its possible, I also plan to upgrade either this winter or next to a gt4094
If you poke around, you'll find info on the 540whp 100% bone-stock B16. It broke all 4 ringlands after a couple dyno pulls and 1/4 mile runs, but still ran okay.
If you want to figure out how far it can go, take a 1.8 or 2.0 that you know the max of and take 5-15% off of that. As long as you can rev it up, the head is the limiting factor, and the monster 1.8's and 2.0's use the same type of head...
Re: Most powerful B16 stock bore and stroke size??? (HiProfile)
You should choose other cams rather than gsr cams for that amount of power, with you wanting 650-700 look at aftermarket stuff (skunk 2, crane cams).
<-- I just ran a 11.4 in my hatch... (14.7PSI
Stock bore b16a...
I've got mahle Pistons and eagle rods...
hitting the dyno next week for some 22PSI pulls w/ race gas
Stock bore b16a...
