blow by
Old Aug 3, 2007 | 01:31 AM
stdefhatch's Avatar
Default blow by
ok so i got my freshly built z6 in my car and got it on the dyno, eagle rods/je pistons and as soon as the car hits boost it starts to shoot oil out the downpipe. am i right by assuming that the rings didnt seat right/installed right?
Old Aug 3, 2007 | 01:44 AM
turbod da's Avatar
Default Re: blow by (stdefhatch)
check your turbo for blown seals..
Old Aug 3, 2007 | 01:50 AM
stdefhatch's Avatar
Default Re: blow by (92gs)
brand new turbo but ill check it, and there was also smoke/oil coming out by the breather so i was told.
Old Aug 3, 2007 | 03:29 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gs &raquo;</TD></TR><TR><TD CLASS="quote">check your turbo for blown seals..</TD></TR></TABLE>
x2, especially if its a thick white smoke !
Old Aug 3, 2007 | 04:27 AM
carnot's Avatar
Default Re: blow by (dturbocivic)
did you perform any type of break-in procedure to make sure everything was hooked up right, there were no leaks, and allow the rings to seat? Was the engine builder around while it was on the dyno?
Old Aug 3, 2007 | 06:13 AM
SOHC_MShue's Avatar
oil coming out your exhaust isn't necessarily blowby. Do you have oil pouring out of your pcv port is the question.
Old Aug 3, 2007 | 08:04 AM
stdefhatch's Avatar
Default Re: blow by (SOHC_MShue)
i followed the breakin proceedure that is on ht, start the car up for 20 minutes to let it idle, change the oil. and then trailored it to the dyno. and no the engine builder wasnt at the dyno. there were no leaks when i had it running at my house and the only time oil is coming out downpipe is when its in boost.
Old Aug 3, 2007 | 08:26 AM
stdefhatch's Avatar
SOHC_MShue
are you thinking i could need an oil catch can run to the pvc ports?
Old Aug 3, 2007 | 08:49 AM
carnot's Avatar
well, you probably know the drill....compression and leakdown tests. If thats good you could pull the turbo off and run a header...if problem goes away, you may have found the culprit
Old Aug 3, 2007 | 08:54 AM
stdefhatch's Avatar
Default Re: blow by (carnot)
true true. thanks for the replies
Old Aug 3, 2007 | 09:12 AM
DaveF's Avatar
fuc break in........... break it in on the dyno......
800+++++ hp to the tires, no break in's here !
Old Aug 3, 2007 | 09:31 AM
stdefhatch's Avatar
well maybe i would if i didnt have oil spittin out my downpipe.
Old Aug 3, 2007 | 06:07 PM
stdefhatch's Avatar
so my best bet is to do a compression/leakdown test, check turbo/check manifold for oil by head ports. and last case would be to pull the motor again........
cooltron
Mar 28, 2008 01:54 AM
2000civic ex
Jul 10, 2007 07:35 PM
!hybrid
May 25, 2006 05:55 AM
zulustypes
Mar 24, 2005 05:00 AM
BooSTED IsLANDER
Feb 9, 2004 01:35 PM
