Most Boost with a profec B?
Old Mar 11, 2003 | 01:32 PM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
Default Most Boost with a profec B?
Whats the most boost you can get out of a profec B? Ive heard only twice of what your wastegate spring is? In my case its a .65 bar TiAL Wastegate so that gives me 1.3 bar. thats like 18lbs of boost .
Anyone?
Old Mar 11, 2003 | 02:01 PM
b00stedbyFastrax's Avatar
Default Re: Most Boost with a profec B? (Boosted2ksi)
i have a .65 tial wg, and got 15 psi on the low setting and about 25 psi at the high setting; now i am using the profec a and can't seem to boost more tha 23 psi. gonna have to do over the learning process b/c of different vacum line routing.
Old Mar 11, 2003 | 02:11 PM
9krpm's Avatar
Default Re: Most Boost with a profec B? (BoostedbyFastrax)
was it turned all the way up? any problems with spiking?
Old Mar 11, 2003 | 03:32 PM
yeah, the low **** was turned all the way and the high **** was about 95% turned. no prbblems with spiking.
Old Mar 11, 2003 | 06:23 PM
boosted3g's Avatar
the selenoid is good for plenty of boost. Ive run mine up to 30 on a few occasions and it held no problem. Greddy also claims 150% of the wastegate setting.
Old Mar 11, 2003 | 06:54 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Most Boost with a profec B? (boosted3g)
The boost controller only goes 14lbs over the wastegate spring rate to a max of 28psi. there is a way to get it to go over 28psi but you need to call greddy to find out how. I knwo it can be done but i never needed more than 28 psi. I have a 20psi spring and high boost all the way up is 28psi even if i spray it it doesnt creep.
adseguy
Nov 12, 2005 09:26 AM
AZNracerx1989
Jul 18, 2005 10:12 AM
yusoslo
Jul 12, 2003 08:01 PM
The Punisher
Jun 21, 2002 09:57 AM
DIRep972
Aug 18, 2001 03:34 AM
