More boost
Old Mar 9, 2004 | 05:00 PM
Harassing Herbs's Avatar
Default More boost
i have a older model HKS BOV. i had to remove the lock nut and screw the bolt on the top all the way to do get up to 7psi. will get more boost with a longer bolt from the hardware store? or would i have to purchase a new BOV to get more boost?
Old Mar 9, 2004 | 05:06 PM
DENCIO's Avatar
Default Re: More boost (Harassing Herbs)
you don't get more boost by adjusting the BOV!!! you need a boost controller manual or elec..
Old Mar 9, 2004 | 06:59 PM
Rusty Shackleferd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harassing Herbs &raquo;</TD></TR><TR><TD CLASS="quote">i have a older model HKS BOV. i had to remove the lock nut and screw the bolt on the top all the way to do get up to 7psi. will get more boost with a longer bolt from the hardware store? or would i have to purchase a new BOV to get more boost?</TD></TR></TABLE>
Old Mar 10, 2004 | 04:30 AM
Default Re: More boost ( HookonBoost )
i have a MBC and when i did turn it up the blov off was only letting the boost go up to 5 psi b4 the springs was opening from the pressure. screwing the Bov bolt all the way down it held pressure up to 7psi. The question was if i used a longer bolt from the hardware store would the spring stiffen to hold more pressure before opening, or would i have to buy a new blow off valve for it.
Old Mar 10, 2004 | 05:08 AM
m R g S r's Avatar
You probally need a stiffer spring in the bov. Actually, something is wrong, any bov should deff. be able to handle more than 5psi without leaking.
Old Mar 10, 2004 | 03:52 PM
Default Re: More boost (m R g S r)
yea the screw was backed out pretty much when it was only holding 5. with it screwed all the way down it holds 7.5 psi. where would i get the spring to put in there? or just save the hassle and buy a new BOV?
Old Mar 10, 2004 | 04:07 PM
Slammd Sol's Avatar
Get a new BOV
Old Mar 10, 2004 | 04:14 PM
Default Re:
my BOV has 2 ports. one on the top front and one on the rear. what is the purpose of the second port??
accordturb96
Sep 20, 2015 03:37 PM
anton_
Jun 24, 2008 09:21 AM
ktran1
Oct 18, 2004 01:29 PM
Nextelbuddy
Jun 12, 2004 06:39 PM
DamonBoost
Jun 4, 2003 08:36 PM
