Missing Link fix retarded boost problem?
Old May 11, 2004 | 06:49 AM
spark plugs.
Guest
Posts: n/a
Default Missing Link fix retarded boost problem?
When i start boosting, the car throws on a check engine light and starts acting all hurt. It bogs, it runs rich, and the exhaust sounds 20349832 louder. From using the SEARCH feature (yes, i already used it) i'm beginning to deduce that it's the stock map sensor reading boost. if i get a 'missing link' from synapse, would this remedy the problem?
Old May 11, 2004 | 07:16 AM
spark plugs.
Guest
Posts: n/a
Default Re: Missing Link fix retarded boost problem? (troublecodes)
bump
Old May 11, 2004 | 08:16 AM
eLusive Acclude's Avatar
yes it should your ecu doesnt like tos ee bost therefore putting the car into limp mdoe hence the bogging and lodu exhuast noise etc. you can also use scuba diving check valves isntead of a missing link
Old May 11, 2004 | 08:30 AM
spark plugs.
Guest
Posts: n/a
Default Re: Missing Link fix retarded boost problem? (eLusive Acclude)
thanks man!
Old May 11, 2004 | 09:06 AM
your welcome ^_^
NJ VTECpowered
Jan 17, 2007 10:06 PM
illestrolla247
Aug 2, 2004 09:06 AM
RuthlessEF-9
Dec 8, 2002 01:36 AM
integraracer94
May 23, 2002 04:19 PM
Turbohatch
Jul 2, 2001 10:35 PM
