missing link + blue box
Old Nov 1, 2005 | 06:03 AM
wiz321654's Avatar
Default missing link + blue box
is it bad to be running the blue box and a Missing link. i removed the FMU and left the blue box, but what about the missing link...will me still running the missing link cause me to lean out?
Old Nov 1, 2005 | 06:16 AM
unclepowers's Avatar
Default Re: missing link + blue box (wiz321654)
the blue box was made to ELIMINATE the missing link so if u have one/check valve throw it out..if u get a check light ur wiring may be wrong..and what engine u have and ahwats the code on the side of the blue box?? (dc2,eg4,em1..etc)
Old Nov 1, 2005 | 12:04 PM
wiz321654's Avatar
i need to check on the blue box, but the engine is a d16y8 , im pulling the missing link today, i am just scared i will run it lean, but if anything im gunna run it lean bc the blue bloc cant see the boost becasue the missing link right?
Old Nov 1, 2005 | 06:51 PM
turbodohcsi's Avatar
the blue box uses the boost to increase the fuel supply, so if your keeping the boost from reaching your map then you dont get any extra fuel = running lean.
Old Nov 5, 2005 | 03:17 PM
what size injectors and turbo u running? i have run t3 turbo on stock injectors. try slightly bigger injectors. 310cc should be more than sufficient.
lDanny
Mar 30, 2005 02:14 PM
311
Jun 15, 2004 02:48 PM
mogz
Dec 10, 2003 03:50 PM
B_1_8_hatch
Jul 22, 2003 10:04 PM
BlackB18C
Apr 15, 2003 11:44 PM
