Missing Link??
Old Jul 29, 2004 | 04:55 PM
illestrolla247's Avatar
Default Missing Link??
ive been told that my car goes into that "limp mode" because i dont have the missing link for the map sensor is this true
the car runs great
untill i boost in 3rd and hold it
then it idles real rough
and sometimes shuts down
anyone know if this is correct and if the missing link will solve the problem
and if so where to get one?
Old Jul 29, 2004 | 05:00 PM
kell211's Avatar
Default Re: Missing Link?? (illestrolla247)
are you getting a cel? how much boost are you pushing, cause if it's more than about 3psi your going to throw a code. and yes, the missing link will stop this from happening. all it does is bleed off enough of the pressure before it hits the map sensor so that your computer never sees the boost. mind you, this has it's own problems with timing and fuel issues.
Old Jul 29, 2004 | 05:31 PM
honda9369's Avatar
what kinda engine do u have,what year car
Old Jul 29, 2004 | 05:41 PM
mpintegra96's Avatar
Default Re: Missing Link?? (honda9369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9369 &raquo;</TD></TR><TR><TD CLASS="quote">what kinda engine do u have,what year car</TD></TR></TABLE> like he said and it probably will solve your problem, i needed one
Old Jul 29, 2004 | 06:10 PM
honda9369's Avatar
Default Re: Missing Link?? (mpintegra96)
well i just hooked up a greddy turbo kit. and im having a simalar problem. but it stalls after giving it throttle.i was told that i didnt need a missing link but now im begining to think that i do 2000 civic ex emanage
Old Jul 29, 2004 | 06:18 PM
gloryhog's Avatar
yes mine did the same after 2nd gear pull to 6psi, and jotech fixed me up wit a missing link. been runnin good for 3-4 months now.
Old Jul 29, 2004 | 10:01 PM
its a 90 hatch with a d16y8 motor
running the hack for fuel management with dsm 450s
im going to purchase a missing link thats what everryones been telling me to get
Old Jul 30, 2004 | 03:17 AM
kell211's Avatar
if you have the hack hooked up correctly, there is no need to run a missing link.
Old Jul 30, 2004 | 06:01 AM
Muckman's Avatar
Moderator in Chief
I have a new missing link I can sell you.
Old Jul 30, 2004 | 06:42 AM
Default Re: Missing Link?? (kell211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kell211 &raquo;</TD></TR><TR><TD CLASS="quote">if you have the hack hooked up correctly, there is no need to run a missing link.
how so????
and how much for the missing link shipped
and i need the one for the map sensor on the firewall not the manifold
if theres a difference whcih i think ther is
Old Jul 30, 2004 | 12:31 PM
Muckman's Avatar
Moderator in Chief
Sent you an email.
Old Aug 2, 2004 | 03:04 AM
kell211's Avatar
Default Re: Missing Link?? (Muckman)
by setting your injectors at the -40% to -35%, you lower your map sensor voltagle below 4 volts. therefore it won't throw a cel. as i said before, doing this causes certain timing and boost under partial throttle problems. but it kicks the **** out of a missing link and a fmu. if your throwing a map code, then my guess is you got something hooked up wrong on the hack.
Old Aug 2, 2004 | 09:06 AM
StolenTeg's Avatar
Selling my missing link 35 shipped
elpiar
Mar 22, 2005 06:02 PM
sol-fire
Aug 25, 2004 09:40 PM
Integra_Boi
Oct 22, 2003 07:55 AM
01ITR#700
Mar 4, 2003 12:17 PM
integraracer94
May 23, 2002 04:19 PM
