Missing 2 main caps to my GE block
Old Aug 22, 2002 | 02:24 PM
h0mesk1let's Avatar
Default Missing 2 main caps to my GE block
My block is at GE as we speak getting turned into a 2.0 gsr. Ive had my main caps and stock block girdle sitting at my house for about a month and my dad accidently thru away 2 main caps. Called the local machine shop, they say they may be able to align and hone/bore two other ones to make them fit, but it will all depend on how close the main caps i bring them are to working. Meaning that it may take many different main caps to find the right one. The machine shop also said that they heard, but havent seen, the JG makes a block girdle/main cap setup that may fix the problem. Anyone heard of this. Can anyone offer any type of suggestion. Dont wanna junk my $1000 GE block
Old Aug 22, 2002 | 02:26 PM
GraphiteAccord's Avatar
Default Re: Missing 2 main caps to my GE block (EGb18cT)
your dad is paying to replace them, right?
Old Aug 22, 2002 | 02:27 PM
niedejb's Avatar
Can you use one of the other bearings/caps and plastigage it to figure out what size you need?
[Modified by niedejb, 5:28 PM 8/22/2002]
Old Aug 22, 2002 | 04:59 PM
earl's Avatar
Default Re: Missing 2 main caps to my GE block (niedejb)
You must use #1 and #5 but ones off a broken block will work. Probably will have to align hone them but any ones off the same model block will work. Your dad owes you big
Old Aug 22, 2002 | 06:07 PM
h0mesk1let's Avatar
Default Re: Missing 2 main caps to my GE block (earl)
only gsr ones will work? How about b16 and ls main caps?
Old Aug 22, 2002 | 06:46 PM
D-Man's Avatar
Buy 2 new ones from the dealer (if theyre available seperate) i would try not to use used caps esp with all that $ wrap up in your block but you might not have any choice, then have the mains align bored,after that,itll be ok.
Old Aug 22, 2002 | 07:38 PM
h0mesk1let's Avatar
Default Re: Missing 2 main caps to my GE block (D-Man)
Dealer only sells a complete block, no way to buy a brand new one.
Old Aug 22, 2002 | 07:47 PM
SEFIxCivic's Avatar
i have some for sale if you want em' which ones you need???
Old Aug 22, 2002 | 07:48 PM
h0mesk1let's Avatar
Default Re: Missing 2 main caps to my GE block (SEFI8LOxCivic)
#1 and #5
b00stedOne
Jun 29, 2010 12:59 PM
DaveF
Northeast (Sales)
44
May 25, 2007 06:41 AM
x91crxsix
Jul 21, 2006 08:59 AM
poorman's type-r
Apr 13, 2006 07:42 PM
LudeyKrus
Jan 1, 2005 05:31 PM
