Main bearing caps?
Old Jun 28, 2010 | 04:16 PM
b00stedOne's Avatar
Default Main bearing caps?
I had my block built for boost but cracked a sleeve. So i picked up another block to build. The main caps look really rusty that came with the new block i got. I was wondering if it is ok to take my main caps off my old motor or does this usually cause problems by miss matching?
Old Jun 28, 2010 | 04:23 PM
nsxter's Avatar
Default Re: Main bearing caps?
would need to be line bored
Old Jun 29, 2010 | 12:59 PM
EG1834's Avatar
Yep, too much of a mismatch, so you would need to bore and hone the mains. You would actually be better off just cleaning the rusty caps (unless the mains are jacked up anyways). Usually some WD40 and scothbrite is all it takes.
toxictom
Engine Machining & Assembly
Jun 24, 2017 10:28 PM
rmcdaniels
Apr 29, 2005 09:51 PM
LudeyKrus
Jan 1, 2005 05:31 PM
Nextelbuddy
Jun 2, 2003 12:32 PM
stayontrack
Sep 19, 2002 04:59 PM
