Old Apr 13, 2006 | 05:18 PM
poorman's type-r's Avatar
* B A N N E D *
Default ???...
okay, i took my other block to the shop and they say that the main caps on it are offset because they're not the original caps off that block. so my question is do you "HAVE TO" use the original main caps or can you still use caps off another gsr or ls block?
Modified by poorman's type-r at 9:39 PM 4/13/2006
Old Apr 13, 2006 | 06:54 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: ???... (poorman's type-r)
I do believe you must use the same ones that are supposed to be mated with that specific block. If not, the other set must be line bored to match.
I'm not 100% positive, but bump for you for more answers.
Old Apr 13, 2006 | 07:42 PM
blkb18's Avatar
Default Re: ???... (shamoo)
when blocks are assembled at the honda factory, the main caps are bolted on to the block and then line honed, and fitted with a crank and specific bearing size. If you mix and match you run the risk of using a main cap that originally used a different bearing size with its original block. The result is a crank journal thats not round.
mario_pic
Jan 8, 2009 03:13 AM
x91crxsix
Jul 21, 2006 08:59 AM
LudeyKrus
Jan 1, 2005 05:31 PM
masterk0ns
Sep 15, 2002 04:35 PM
h0mesk1let
Aug 22, 2002 07:48 PM
