Miss-shifted....Is anything wrong?
Old Jan 24, 2002 | 02:50 PM
KhRoNiX's Avatar
Default Miss-shifted....Is anything wrong?
Well my engine is ticking louder, but could anything else be wrong? I don't have a rev-limiter (I know thats dumb) and hit over 9000 rpm for a SPLIT second (I have a stock valvetrain). Please tell me what I should do. TIA
Old Jan 24, 2002 | 04:12 PM
2000_Civic_Si's Avatar
Default Re: Miss-shifted....Is anything wrong? (KhRoNiX)
I would reccomend doing a compression test, and inspecting the spark plugs. I might even do a oil change just to make sure nothing got messed up. If all checks out ok, then it seems you have gotten lucky.
Old Jan 24, 2002 | 04:22 PM
DIRep972's Avatar
Smarter than you
hopefully u didnt bend a vavle.. my friend tached to like 9700 on his B20vtec w/ type R head, bent all the valves in the head.. the ticking was crazy, like scary to drive.. definitly do a valve adjustment/..
Old Jan 24, 2002 | 05:13 PM
turboex's Avatar
Default Re: Miss-shifted....Is anything wrong? (DIRep972)
my friend shifted his b16a at 90mph into second and the motor was totalled. however he hit 10,000+rpm on his new motor or thats what the memory on his autometer tach said and there was no damage at all. how did he do this? He miss shifted from 3ed to second at 70mph. imagine that. and his new motor is a LS/VTEC crazy huh. im sure you have all seen the b16a crx blowing the motor in the video thats all over the place, its the one with "in the end" playing in the back ground. oh your answer. compression test. sorry for the long post
Old Jan 24, 2002 | 05:35 PM
DIRep972's Avatar
Smarter than you
Default Re: Miss-shifted....Is anything wrong? (turboex)
never seen that video, hook me up with a link..
Old Jan 24, 2002 | 06:41 PM
turboex's Avatar
theres the link, you will have to unzip it when its downloaded. tell me what you think. also i can get pics of the block and head if anyones interested, there still in the shop. I also have the video of this car with the LS/VTEC playing with a mustang and a few other vids if anyone is interested.
http://clutorrtechvideos.homestead.c...orblowncrx.zip
[Modified by turboex, 3:41 AM 1/25/2002]
Old Jan 24, 2002 | 10:20 PM
DIRep972's Avatar
Smarter than you
hell yeh im interested.. Hook ME up foo!
Old Jan 25, 2002 | 03:21 AM
turboex's Avatar
i think this is the mustang one
http://clutorrtechvideos.homestead.com/files/steve2.zip
and this is one of the motor, launch. and a little run
http://clutorrtechvideos.homestead.com/files/newcrx.zip
heres a few pics of the head after the mtor blew.
Old Jan 27, 2002 | 11:20 AM
KhRoNiX's Avatar
Alright I just did a compression test....
Cylinder#1 = 170
Cylinder#2 = 160
Cylinder#3 = 170
Cylinder#4 = 180
Tell me what I need to do next...
Old Jan 27, 2002 | 12:02 PM
BoM's Avatar
BoM
did u do the test with the throttle at WOT?
those numbers are low, u should be above 200.
there is a problem.
Old Jan 27, 2002 | 12:20 PM
SiR Kid's Avatar
New User
Default Re: Miss-shifted....Is anything wrong? (BoM)
Hey turboex.... These look familiar? These came out of my B16 when I broke a timing belt at 8k rpm
Old Jan 27, 2002 | 01:37 PM
turboex's Avatar
Default Re: Miss-shifted....Is anything wrong? (SiR Kid)
yeah man, there nothing like seeing valves come out the tail pipe.LOL
Old Jan 27, 2002 | 01:41 PM
csufweed's Avatar
BOTTOM LINE...
CHECK YO VALVES!
Old Jan 27, 2002 | 02:25 PM
miller's Avatar
Default Re: Miss-shifted....Is anything wrong? (csufweed)
damn straight!! check those bad boys!
Old Jan 27, 2002 | 03:33 PM
KhRoNiX's Avatar
Oh by the way... I have 9:1 CR pistons so that may be the cause for a lower compression. Also, I did not do it at WOT. Im gonna go do another test and Ill get the new numbers.
Old Jan 27, 2002 | 06:23 PM
KhRoNiX's Avatar
ttt
Old Jan 29, 2002 | 11:38 AM
X2BOARD's Avatar
CHECK YOUR VALVES.... You prolly at least need a valve adjustment... if your valves haven't been bent by the over rev... If the tapping continues after a valve adjust... they might be (some or all) bent.
Good news: I misshifted the other night, 9K, low comp pistons 9.2:1 luckily I did not bend any valves... from 2nd to 1st.... don't ask
GodSpeed...
zccrx
Nov 12, 2008 07:26 AM
NA_DA
Aug 28, 2008 07:53 AM
spoonhatchblack
Nov 6, 2005 09:38 PM
311
Jan 17, 2003 08:29 PM
shamoo
Sep 15, 2001 01:07 PM
