Meziere Pump Leaking....errrrrr Anybody ever see this?
So for the last couple of weeks Ive had the coolant leak from under my Meziere Water pump. I also changed the Hoses of to Greddy and I cant tighten the clamps anymore on the hose ends. So a couple of alan heads later the pump is of and I see the leak.... right on the pump right in between the mounting bolt holes is a small hole about 3/16"s. Leaks from out this hole?? Buy looking at the mounting bracket which is blue anodized you can see where the leak changed color and is now burned on the surface. There is no mention of this or a picture of the pump on the instructions, Meziere.com is no help either.
