melted pistons
Old Feb 25, 2010 | 04:21 PM
  #76
SD_Lurker's Avatar
HT White Ops
Default Re: melted pistons
Originally Posted by jprelude92
the tuner called me today and said that he talked to someone from hondata and that he described what happend to the pistons and that the guy at hondata said that he's seen pistons like that before and that is cause by a lean condition he said that some injectors might work fine at 90% duty cycle but might not work well at 60% or 40% , i dont know yet what duty cycle my injectors were working at whent the engine blew up but the tuner is gonna let me know so i can send the injectors back to precision to have them flow tested at the cycle they were working when the engine fail
I think the tuner is trying to find any reason to take the attention off himself. Why hasn't he sent you the file to share with others? I think he knows he ****ed up.
Old Feb 25, 2010 | 04:51 PM
  #77
ashb82's Avatar
your tuner can say what ever he wants bad tuning caused that. how many pulls did it take for this to happen. I noticed that you said u had a EGT sensor. low egt can also be a sign of detonation. Did he shut the car down and check the plugs
Old Feb 25, 2010 | 04:57 PM
  #78
ls_on_boost's Avatar
you live in fort myers u should have had kenny aka turbo gixxer tune your car #1 he knows his **** my ls is on 16 degrees timing and its my dd but i dropped a valve last week and got a vtec head now she's ready to go back to kenny
Old Feb 25, 2010 | 10:19 PM
  #79
Bugermass's Avatar
Originally Posted by Scott_Tucker
No, that's correct.
Abnormal combustion can generally be divided into two categories. Pre-ignition combustion and post-ignition combustion. Pre-ignition is anything that sets off the mixture before the spark plug fires and post-ignition is anything that sets it off in an area ahead of the flame front after the spark plug has fired.
Pre-ignition will show up as pock marks on the top of the piston and will eventually eat a hole in the center of the piston if it is allowed to progress far enough. As mentioned before it usually occurs due to a 'hot spot' in the combustion chamber. Continued pre-ignition will promotepost-ignition so sometimes you will have both types of damage.
Post-ignition (generically called 'detonation') occurs when the spark plug fires, the flame front begins burning, and the 'end gases' which are the unburnt air fuel mixture ahead of the flame front spontaneously combusts due to the pressure and temperature in those end gases reach the ignition temperature of the fuel. It shows up as damage to the ring lands on the edges of the piston. The reason it does this is because the spark plug is in the center of the cylinder and the flame front spreads out radially. This compresses the end gases which are at the outer edges of the cylinder. When the end gases explode the pressure in the cylinder in that area spikes high enough to damage the ring lands. The violent vibration of the two flame fronts colliding also increase the heat transfer which is why the ring lands may look melted.
I can not say why his engine detonated. It could be because the tuner had the ignition too far advanced or it's possibly the engine is built wrong. If there is not a proper quench area (meaning there is excessive clearance between the top of the piston and the cylinder head) on the edges of the piston it can cause this which would not be the tuners fault.
I agree with some of what your saying, but the cause/effect that you have basically set in stone, is not always the case.. I've seen motors with pock marks that were definatly caused by detonation, and I've seen pistons melt the way those are melted with no knock/detonation present. It only takes 1-2 strokes for pre-ignition to melt a piston like that depending on the conditions right before it happens.
Old Feb 26, 2010 | 05:37 AM
  #80
jprelude92's Avatar
i guess its too late for that i didnt know about that guy kenny
Old Feb 26, 2010 | 05:41 AM
  #81
jprelude92's Avatar
we were on the highway when this happend so no we didnt check the plugs
last time when he set the mechanical base timming i swear he said that he set it to 30 degrees cuz i asked him and when i asked him today he said that it was at 20 degrees so right there i know that hes trying to cover his butt
Old Feb 26, 2010 | 05:44 AM
  #82
jprelude92's Avatar
he just sent me the file but would'nt doubt he edited the file to make himself look good.
i want to post it but i dont know how to maybe some1 can tell me how its on my hot mail address
Old Feb 26, 2010 | 05:51 AM
  #83
jprelude92's Avatar
Originally Posted by tepid1
Tell you what.... I am still a mod over on the Neptune forums. You can post your file there or you can email it to me so I can take a look at it. If you want to email the cal file send it to: tepid1@sbcglobal.net
i just sent you the file to your email maybe you can post it here cuz i don't know how to
thanks
Old Feb 26, 2010 | 07:47 AM
  #84
ashb82's Avatar
mechanical base timing are you talking about the distributor or the idle part of your tune
Old Feb 26, 2010 | 08:23 AM
  #85
blaze the chemi's Avatar
What did the timing light say at idle and what is your timing according to your Neptune when it blew? I definitely want to see what the table looks like.
Old Feb 26, 2010 | 08:29 AM
  #86
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Todd actually tuned my car as well... He is an EFI 101 grad, and been tuning for a long time. He is more than fluent in engine theory, and tuning. That being said, people make mistakes, but like I said before, I am curious to know if you are even able to set your mechanical base timing to 30deg... Through my experiences with him, I found that he is a good guy, and won't leave you up ***** creek (coming from a customer, not friend).
Old Feb 26, 2010 | 08:37 AM
  #87
ralph11sec's Avatar
there could be a reason why the tuner set it at 30. reasons i dont understand.
first of all why does he say ign is at 30 at idle when his laptop shows 21 or so. doesn't he know he has to sync it? anyway it doest matter what ign you have at idle. it won't cause that damaga. as long as it's the same with the timing light and datalog.
what we want to know is how much ign do you have at 12/14 psi. you are using a 3bar map sensor i suppose.
Old Feb 26, 2010 | 08:39 AM
  #88
BOOSTED RHD CRX's Avatar
the whole situation sucks but with a motor build like that and everything done to the car u did skimp on one thing... the tune.. that's not me bashing on the tuner. it should have been on a dyno so u can see all the numbers after each pull and make appropriate adjustments. sorry that stuff happened. i am about to get my fully built motor tuned and im real nervous cuz i don't want the thing to blow up on the dyno after spending all this time and money getting her all set. i at least want to blow it up at the track or on the street smashin on a cocky *** vet owner : D
Old Feb 26, 2010 | 08:40 AM
  #89
ralph11sec's Avatar
Just upload it to any hosting site like photobucket.com then post the image link here enclosed with [IMG]type url here[/IMG]
anyway about the DC. that is not accurate.
it will depend if you set your parameters right in fuel trim. but, even so, it won't be the correct actual DC.
you guys should have done plug reading. TUNING 101!
Old Feb 26, 2010 | 08:53 AM
  #90
jprelude92's Avatar
i'm talking about timming you adjust with the distributor and timming light
Old Feb 26, 2010 | 08:55 AM
  #91
jprelude92's Avatar
i know hes not a bad guy but i have heard more bad things about him than good
Old Feb 26, 2010 | 08:57 AM
  #92
jprelude92's Avatar
i,m using a 4 bar map sensor
Old Feb 26, 2010 | 09:10 AM
  #93
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
what else have you heard? when exactly did this happen?
Old Feb 26, 2010 | 09:20 AM
  #94
jprelude92's Avatar
it happend wednesday about a 1 ago he tuned the car and it detonated or predetonated and it cracked the head gasket when i pulled the head on the intake side of the pistons was pitted but nothing major so i put the head back and took the car back to him cuz from the begining when he tuned it it wasn't running right so told me to bring it back and he'll street tune it
Old Feb 26, 2010 | 09:24 AM
  #95
jprelude92's Avatar
also chech out my other thread title je pistons got melted and look at what happend he blame it on the machine shop saying that the piston to wall was too tight but now i dont think it was piston to wall cuz he was the 1 woho tuned it it cant be a coinsidance 3 times in a row something goes bad every time he tunes the car some thing happens
Old Feb 26, 2010 | 09:33 AM
  #96
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
what?
Old Feb 26, 2010 | 09:45 AM
  #97
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Has the same machine shop been doing the work throughout these three separate occasions? I find LSVTEC to be harder to keep together than a stock b-series, I find h22 to be a little tricky than b-series, so I personally would be terrified of an LSVTEC h-series lol
Old Feb 26, 2010 | 09:57 AM
  #98
jprelude92's Avatar
two different machine shops did the work
my engine is a build h23 non vtec my bad i meant to say it was (RIP)
Old Feb 26, 2010 | 10:03 AM
  #99
jprelude92's Avatar
my car blew up on his dyno about 3 months ago like i said before check out my othe thread he said he didn't know what happended he blame it on the machine shop and i bealived him i gave him the benefit of the doubt not anymore this is the third time he messes my car up.
Old Feb 26, 2010 | 10:06 AM
  #100
jprelude92's Avatar
also i know another guy that todd did a head job he change valves springs and tuned the car and he droped a valve and like him and this other guy theres more another guy i know threw a rod on a turbo scion with 6,000 miles on the engine the same day after todd tuned his car
