melted pistons
Old Feb 28, 2010 | 10:26 PM
  #176
Scott_Tucker's Avatar
Default Re: melted pistons
Originally Posted by Glove
unless the guy offered to pay for all the damage, I cant see why you would retract your complaints
I don't see what slamming the tuner is going to achieve. No one except the original poster and the tuner were there when the car was being tuned and they are the only ones who knows what really went on. This could have easily been a design problem with the engine that the tuner could not have anticipated. Even though the evidence currently points to errors by the tuner, we do not know for a fact that this is the case.
I agree with the OP's retraction.
Old Mar 1, 2010 | 04:03 AM
  #177
wolve's Avatar
Originally Posted by LowBudgetBEe
then the only person to blame is yourself. thats why i tune my own car, build my own motors, trannies, whatever......and its also cheaper.
AMEN!!!
then at least you know where to point the finger at, blew 1 up myself. learned from it
Old Mar 1, 2010 | 07:39 AM
  #178
Glove's Avatar
the OP asked for opinions, and posted maps ect.
and were all saying its the most likely the tuners fault, and also its been pointed out that he has blown multiple motors while tuning,
all 4 pistons melt? thats sure as hell not a design problem.
Like i said, the only reason he retracted was either the tuner threatened him with something, or offered to pay for something.
Old Mar 7, 2010 | 02:09 PM
  #179
jprelude92's Avatar
i asked the tuner if he jump the jumper wire to check the timing and he said that it doen't need to be jump cuz we are not using a stock ecu is he right or wrong?
Old Mar 7, 2010 | 04:17 PM
  #180
ls_on_boost's Avatar
i think he's wrong i think you have to jump it
Old Mar 8, 2010 | 08:03 AM
  #181
jprelude92's Avatar
is there any tuners in here that can give me their opinion on this
Old Mar 8, 2010 | 08:16 AM
  #182
Glove's Avatar
im not sure about hondata,
but in ectune you can lock the ingition to 16 degree's without jumping the service connector.
Old Mar 8, 2010 | 08:26 AM
  #183
TimKennard's Avatar
same in neptune also
Old Mar 8, 2010 | 04:40 PM
  #184
ralph11sec's Avatar
no.
in s300 there is a ign set there...
its under one of the menu bars....
nonetheless, he should do that via datalog. and see what's the ign there.
Old Mar 8, 2010 | 07:36 PM
  #185
Bugermass's Avatar
We get cars in all the time for tunes, that were either E-Tuned or tuned by some "tuner" from so and so shop or whatever and they are already toast.. I can't tell you how many people I've had to turn away because their motor was already hurt when they got there.. Most of these guys go for the "cheaper" tuning solution and endup paying more in the long run.. I hope you get your motor back together..
Old Mar 9, 2010 | 09:41 AM
  #186
jprelude92's Avatar
right now i'm trying to sell everything that didn't get mess up when the engine blew like the head ,cams ,conecting rods, ect so i can buy a jdm f20b blue top and just go with 5 psi
Old Mar 9, 2010 | 09:45 AM
  #187
jprelude92's Avatar
oh by the way i got the results back from precision turbo and they said my injectors were fine they flow test them at 45,66and 90%duty cycle, fuel pump is fine too .
Old Mar 9, 2010 | 01:29 PM
  #188
SD_Lurker's Avatar
HT White Ops
Ok well whatever.. At this point what is the purpose of the thread? People have given their opinions in regards to your situation.. All the sudden you come into the thread and cover your tuners *** with blah blah blah. So really why does this thread still exist? Why the **** would you sell your sleeved block for a stock one? Why not build the motor one more time and take it to someone who knows what the **** their doing?
Old Mar 9, 2010 | 02:20 PM
  #189
jprelude92's Avatar
i want to sell everything cuz i'm done i just want to put another motor and sell the car and maybe in the future get and evo
Old Sep 29, 2011 | 07:59 AM
  #190
tazihonda's Avatar
Hi guys n girls, first post! Tazzie from over at prelude*****.com! I realise this thread is a bit old now, just came across it whilst lookin around! Thought id register an account and add my 2c worth! Jeez, id hate too be that tuner, i got to say, people bagging him out without in my opinion any evidence he did anything wrong here! An internet wide story like this could destroy someones business or even get them seriously messed up! No, i dont even know this guy, im from aussie, other side of the world!
Here is what i reckon has happened based on what ive seen and read,
Problem 1, he used the wrong size head gasket initially causing pre-ignition due to the hot edge where it was protuding into the bore, it may even been tapped by the piston a few thousand times!
problem 2, Major oil consumption, the pre ignition may have cracked the ring lands, and as a result began burning oil, but more likely there was excessive piston-bore clearance, excessive ring end gap, problem with the head or breather system or a leaky turbo.
Either way, it is this oil consumption that has caused this engine to melt down, not too much timing, hot carbon causing pre-ignition, oil reducing octane of mixture, and basically blowtorching the pistons.
It may have even been a design fault with the pistons, forged pistons have a bad tendency of uneven expansion as they heat up if they are not engineered correctly or beaten on when cold, close up pics may show more clues here.
Also how much quench clearance were you running?
Id be more inclined to blame the engine vs the tune, and i think the damage was probably already done from the headgasket incident, wasnt correctly diagosed and snowballed from there.
Anyways just my opinion.
Gday to all! Hope you fixed ya engine!
Cheers
Old Sep 29, 2011 | 10:09 AM
  #191
LocoJoe's Avatar
Old Sep 29, 2011 | 02:57 PM
  #192
jprelude92's Avatar
lol @ loco joe thats a good one
Old Sep 29, 2011 | 05:37 PM
  #193
ashb82's Avatar
I will not tune a car with all that wrong with it. If a car is heating or smoking i tell them the car has to be sound before i will tune it. i dont try to sound like *** but i tell them what needs to be fixed.
stoney0078
Mar 25, 2009 09:57 PM
Suck my DX
10
Dec 28, 2006 06:30 PM
Cyphear
Nov 22, 2004 03:12 AM
H2nr
Aug 29, 2004 10:08 PM
{StatuS ChecK}
Aug 27, 2004 02:43 PM
