MBC with internal WG?
Old Apr 6, 2005 | 11:05 AM
92civicb18b1's Avatar
Default MBC with internal WG?
Can I use an MBC with an internal WG?
I assume I can, and just put it in between the WG and compressor housing's line. Correct?
Old Apr 6, 2005 | 11:11 AM
YiNYaNg's Avatar
Default Re: MBC with internal WG? (92civicb18b1)
It's best if you get your line hooked up too your intake manifold since that's where it really matters. You'll also have better spool up if you do that...
Old Apr 6, 2005 | 11:49 AM
Default Re: MBC with internal WG? (H-T)
So I should run a line from the WG to the MBC to a "T'd" off vacuum line from the IM?
I just want to get the right idea of it before I make/buy one.
Old Apr 6, 2005 | 12:15 PM
Evanmb44's Avatar
run a line from the intake manifold(you can tee off of a line there already) to the MBC and then a line from the MBC to the wastegate actuator. i ran that way for a while when i had an internally gated turbo. works fine
crex23
Mar 16, 2014 02:37 AM
Wickedsol94
Aug 8, 2006 08:13 AM
Muckman
Apr 18, 2006 03:42 PM
.RTErnie
Dec 3, 2005 05:29 PM
turbochargeb18c
Sep 5, 2005 08:36 PM
