mbc install on ls
Old Nov 27, 2008 | 04:13 PM
91lsturbocrx's Avatar
Default mbc install on ls
I know this is probably a stupid question, but can anyone please tell me where the boost pressure sensing connection would be at on my car? And any other tips are greatly appreciated, I don't wanna screw anything up
Old Nov 27, 2008 | 05:18 PM
turbociv910's Avatar
tb.
Old Nov 27, 2008 | 06:38 PM
xenocron's Avatar
Think about it really carefully...you can answer your own question.
What part of the "system" sees boost and could be used as a good "boost reference"
Also, think of which sensor reads boost...and maybe get the signal for the wastegate/mbc from the same or similar area.
Old Nov 27, 2008 | 09:33 PM
HiProfile's Avatar
You are such a jerk, a normal person could never guess.
You can use almost any vac line, but you should really use a large feed, such as a vac manifold running off the brake booster line. Tial recommends boost-only (pre-TB), but thats to put less long-term stress on the diaphragm. Either will work, but the post-TB setup will close the WG between shifts to help prevent falling out of boost.
Old Nov 28, 2008 | 06:35 AM
alright thanks hiprofile I'll give that a shot, and I have another question, To get my ls tuned, do I have to get a jumper harness and change ecus? Or can it just be tuned the way it is?
sanman000719
Sep 2, 2011 02:16 PM
zach1288
Jul 8, 2010 02:39 PM
K7-1Ktrevor
Dec 20, 2009 04:02 PM
Silva Bullit DC4
Jan 17, 2008 02:06 PM
importboi22
May 20, 2004 04:43 AM
