84mm in b-series, boring out stock sleeve ok?
just wondering if anybody's running 84mm slugs boring out the stock sleeves? way too thin of walls? should I sleeve first then bore to 84mm??
by the way, this is for a turbo setup. wanna push at least 400-500whp.
Re: 84mm in b-series, boring out stock sleeve ok? (Honda Sport)
Not going to happen on stock sleeves. You will have to get after market sleeves if you want 84mm. The most you can do on stock sleeves with boost is 81.5mm.
Re: 84mm in b-series, boring out stock sleeve ok? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">Not going to happen on stock sleeves. You will have to get after market sleeves if you want 84mm. The most you can do on stock sleeves with boost is 81.5mm.</TD></TR></TABLE>
crap. lol, not much leeway considering oem is 81mm. oh well...I guess it's time to sleeve
Re: 84mm in b-series, boring out stock sleeve ok? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">There is a guy around here punched out to 84mm but it was all motor</TD></TR></TABLE>
oh yeah? who's that? I wanna check out his setup...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport »</TD></TR><TR><TD CLASS="quote">
oh yeah? who's that? I wanna check out his setup...</TD></TR></TABLE>
He doesnt have that setup anymore. he is running a sleeved block now.
Re: 84mm in b-series, boring out stock sleeve ok? (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">Ive seen it done one time all motor and all the sleeves cracked...</TD></TR></TABLE>
in other words, no...lol. thanks for the input.
Re: 84mm in b-series, boring out stock sleeve ok? (ek9vboi2)
b20s come 84 mm and have different sleeve thickness then a gsr or LS /B16..its not the same as broing out a 81mm block to 84
lemongreenhatch
103
11-16-2004 05:37 PM
