map sensor?? what do i use for more than 11 psi
Old 03-28-2006, 06:52 AM
boostedhatchsi's Avatar
Default map sensor?? what do i use for more than 11 psi
i have been told to use a gm 3 bar map sensor for using more than 11lbs of boost to my ls swapped hatch the ? is how do i do it and what gm cars can i get that map sensor from also is that the best map sensor to use with no more than 15 lbs of boost ever to be honest im best with pictures but i will use all the help i can get to get this and get it installed
thanks for any info you can provide me
Old 03-28-2006, 07:17 AM
wrenchin'
I Have an STD's Avatar
Default Re: map sensor?? what do i use for more than 11 psi (boostedhatchsi)
u need to search buddy. the gm sensor is available through a LOT of dealers. u can also use the motorola 2.5bar sensor which is good to 21 psi.
Old 03-28-2006, 10:17 AM
Default Re: map sensor?? what do i use for more than 11 psi (I Have an STD)
well as far as the motorola 2.5 bar what is that off of and im also looking for installation instructions
Old 03-28-2006, 10:42 AM
A.E Motoring's Avatar
u can buy it here https://honda-tech.com/zerothread?id=1551143
Old 03-31-2006, 04:27 AM
where can i find an installation diagram for the gm map sensor ? is that better than the motorola?
Old 03-31-2006, 05:16 AM
VI Boost's Avatar
Default Re: (boostedhatchsi)
https://honda-tech.com/zerothread?id=1263795
this has a diagram with instructions on how to wire a gm 3 bar.
woojdm
06-09-2009 08:54 PM
mrx
Engine Management and Tuning
12-29-2008 06:30 PM
Civicman86
09-21-2006 08:25 PM
fast[R]
07-18-2002 03:00 PM
Quick Reply: map sensor?? what do i use for more than 11 psi
