Which MAP sensor can I use with the AVCR?
Old Sep 18, 2006 | 02:16 PM
Civicman86's Avatar
Default Which MAP sensor can I use with the AVCR?
I have an AVCR but the sensor has gone to junk. A buddy of mine said the avcr can be used with a few different type of map sensors. Anyone know which ones I can use? Would a GM 3 bar be able to work?
Old Sep 18, 2006 | 02:48 PM
Mugencrxsir1's Avatar
Default Re: Which MAP sensor can I use with the AVCR? (Civicman86)
What type of engine management are you running? Yes most of the time you can us a GM 3 bar map sensor, I know with hondata you can...
Old Sep 18, 2006 | 02:55 PM
Civicman86's Avatar
uberdata...going to crome eventually
Old Sep 21, 2006 | 08:08 PM
Civicman86's Avatar
anyone confirm that I can use the gm with the apexi? I like at least one more to confirm before I go off and buy it. TIA
Old Sep 21, 2006 | 08:25 PM
Tchleung's Avatar
No you cannot use the GM map sensor. Just so everybody is clear, the map sensor he is talkngi about is the BOOST CONTROLER map sensor, not the EMS map sensor. You need the Apexi map sensor. Be sure to tell people the AVCR is a boost controller, otherwise poeople will keep tellnig you to use any map sensor that works with yuor EMS, which you are not asking about.
woojdm
Jun 9, 2009 08:54 PM
dseriesdrag
Sep 21, 2006 09:32 PM
adeihl
Sep 2, 2004 04:21 AM
