map sensor problem
Old Dec 17, 2002 | 08:37 PM
wanabecivicex's Avatar
Default map sensor problem
should i, or should i not trust my map sensor's reading of boost?
here's my delema. my map sensor used to show positive intake manifold pressure, now, when i seem to be boosting, it shows no positive pressure, only 0, and my pressure at idle is alot lower too. what do you think is wrong? map sensor?
thanks
Old Dec 17, 2002 | 09:54 PM
Speed PHreak's Avatar
Default Re: map sensor problem (wanabecivicex)
Ummmmmmmm clarify? What are you using to read your MAP sensor? It also outputs on a 0~5 volt scale, with approximately 1V being idle, 2.89V being WOT, and 4.8-ish being 11psi of boost. The stock Honda MAP won't read over 11psi.
Old Dec 17, 2002 | 10:02 PM
Default Re: map sensor problem (Speed PHreak)
im using a apexi afc to read the pressure. at idle, it usually reads around 530-540, i have 2 check valves before the map sensor
Old Dec 17, 2002 | 10:14 PM
Sorry, never used a AFC with my boosted setup, wish I could help more. But if you've got 2 check valves before the MAP sensor it shouldn't be reading any boost. If it does you'll throw a code(MIL/CEL on the dash) with a stock ECU. Unless your doing the AFC/450cc injector hack then i'm really clueless on that part
[Modified by Speed PHreak, 2:16 AM 12/18/2002]
Old Dec 17, 2002 | 10:17 PM
actually, i believe the map sensor can read up to .6 mm hg before it throws a cel
Old Dec 17, 2002 | 10:26 PM
it's 11 psi, trust me......I've test it
Old Dec 18, 2002 | 06:07 AM
RAWB's Avatar
thanks
If your using the Missing Link or the "check valve" setup, your MAP won't see the boost, that's what you want.
I have the ML, and my VAFC manifold pressure reads 0, even though my boost gauge reads 10psi.
Old Dec 18, 2002 | 08:28 PM
Default Re: map sensor problem (integracon)
ok, well the deal is, i got my boost guage in today, hooked it up, and im only running 1.5 lbs. i have narrowed it down to: leak in exhaust manifold, leak in intake manifold, and possibly..............blown ring on piston i cant figure this **** out....any other suggestions?
krugozor
Feb 21, 2011 08:38 PM
hatchBK4life
Feb 3, 2010 12:08 PM
95civicohyeah
Nov 5, 2007 06:31 AM
HiGhCaM
May 11, 2002 11:40 PM
