Map sensor block off plate?
Old Apr 24, 2003 | 09:53 AM
  #26
Boostless97Lude
Guest
Posts: n/a
Default Re: Map sensor block off plate? (98lude)
no, i was using the basic desing of that bypass as a basis for a combination block off plate/vacuum line for a 3bar map..... just visualive the pic WITHOUT the check valve
Old Apr 24, 2003 | 09:56 AM
  #27
98lude's Avatar
Default Re: Map sensor block off plate? (Boosted97Lude)
that I understand, but still not JT's comments, which basically say what you are trying to do is incorrect.
Old Apr 24, 2003 | 10:04 AM
  #28
TurboDANDEE's Avatar
well JT is wrong because the original place where the stock MAP sensor goes does see vacuum and boost.
Old Apr 24, 2003 | 10:06 AM
  #29
JRSCCivic98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lude &raquo;</TD></TR><TR><TD CLASS="quote">that I understand, but still not JT's comments, which basically say what you are trying to do is incorrect.</TD></TR></TABLE>
JT is smoking crack
J/K... The reason why you're not getting this 98lude is because what JT said last would hold true only in a supercharger (JR) setup. Basically if you TB location for the map sensor doesn't see boost (with a JR supercharger it won't) then you have to move it to somewhere at the manifold after the air is compressed. Be it either the stock map sensor or a 3BAR one. If you're turbo or Vortech charged then the stock location can be used to see both boost and vac. The picture above with the t fittin in the plate and a checkvalve is representative of a cheap "missing link" setup. Get rid of the checkvalve in the setup and you got what you want if you are turbo and need to put a 3BAR sensor on.
Hope this helps...
Old Apr 24, 2003 | 10:10 AM
  #30
98lude's Avatar
Default Re: Map sensor block off plate? (JRSCCivic98)
thanx a bunch. Now I understand why JT said that. Never gave much thought to supercharging.
This clears up a bunch. thanx
Old Apr 24, 2003 | 10:13 AM
  #31
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lude &raquo;</TD></TR><TR><TD CLASS="quote"> thanx a bunch. Now I understand why JT said that. Never gave much thought to supercharging.
This clears up a bunch. thanx </TD></TR></TABLE>
Superchaging... WHAT'S THAT???
Old Apr 24, 2003 | 10:28 AM
  #32
JT's Avatar
JT
Hahaha... sorry for the confusion guys . I wasn't thinking about turbo when I made the original post. I later realized the different setup and edited the post.
guy_from_nerk
Feb 18, 2008 01:26 AM
allnaturalb16
Oct 19, 2007 10:14 PM
kornerk12
May 29, 2007 05:26 PM
zman
Jun 15, 2006 07:40 PM
Si Shane
May 24, 2005 01:14 AM
